Why do I even bother with these aftermarket.....!!!!
#1318081
10/09/12 10:10 PM
10/09/12 10:10 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
Big block thermostat housings. Fired up the 440 Sixpack for the first time in the 71 R/T Challenger. All in all eveything went very well. The carbs reminded me that you always need to check for leaks at the fuel lines, but that was a quick and easy fix. Ran the engine, got the timing set and everything sounded great(especially with open headers) Ran it for awhile to get some temp in it. The engine has always ran very cool so it took awhile to get it warm, I thought I was in the clear with any leaks...then I noticed coolant weeping under the rear of the the housing. Tried to tighten the bolts down but I don't think that will work. It's the thick Milidon housing that some have had success with. I used a new gasket with some Indian Head shellac for sealer...maybe that was my mistake. I've NEVER had any luck with these POS aftermarket housings. So I'm very happy with everything except the housing...I should have known better. It sure was nice to DRIVE the car into the garage instead of pushing it like I've done for soo many years. So time to drain the coolant and try again. I'm not sure if I'm gonna try to seal it or go back to my tried and true stock housing. Any suggestions?
Re: Why do I even bother with these aftermarket.....!!!!
[Re: RapidRobert]
#1318084
10/09/12 10:54 PM
10/09/12 10:54 PM
Posts: 1,880 Out in Left Field, NY
bobs66440
Any suggestions?
I just went through exactly the same thing with mine. If you take it off, I'm sure you will see that it is warped (bent down at the ends and up in the middle. The more you tighten it, the worse it gets. You can grind/file it flat and it will do it again. This has happened to me too many times. They are all crap. Do yourself a favor. Chuck it in the trash and use the OEM one.
[Re: rss]
#1318088
10/09/12 11:06 PM
10/09/12 11:06 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
I believe someone now making one with an o-ring seal.
Chevy ones are the same so there's plenty out there to choose from.
[Re: jerseybud]
#1318089
10/09/12 11:13 PM
10/09/12 11:13 PM
Posts: 181 Stow,Ohio
RBSat66
Stow,Ohio
I'm using a housing made by Billet Specialties on my 440 and have never had a leak. Part number is 90820. Very nice piece with the O ring it is an easy sealing housing.
[Re: KillerBee]
#1318092
10/10/12 01:38 AM
10/10/12 01:38 AM
Posts: 18,160 Mass
DAYCLONA
Mass
I got 2 of the newer Milidon chrome necks in use, neither one leaks, I've had some of the older necks, that were just junk, and a few with no issues over the years, I have an old CalCustom on my Challenger T/A...it's been on for about 30 yrs now!, and still looks good
...anyway, recently installed one (Milidon) in my kids Dodge truck, toss the gasket supplied, use a Duralast gasket (Autozone/parts store) PN# 35063 it's a lot thicker, install the gasket first using a film of Permatex Gold engine sealant under the gasket, after gasket install, add another film of Permatex Gold, then install the thermostat, then add the housing, tighten to spec evenly, should be ready to add coolant in about 1 hr...I've seen some guys put the thermostat down first then the gasket over it, that's an issue too,..plus that Indian head sealer some like to use is problematic as well, as well as form-a-gasket
Mike
[Re: Commando1]
#1318096
10/10/12 10:17 AM
10/10/12 10:17 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
Hard to seal anything against chrome. Like RapidRobert says, a big O' file is your friend. I file old originals back to a nice flat, smooth surface. Removing chrome for a good seal is a must to me.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#1318097
10/10/12 01:25 PM
10/10/12 01:25 PM
Posts: 2,190 SW MO
closer9
SW MO
Didn't get mine from Summit, but I'm running an SS one on my 318. http://www.summitracing.com/parts/PRS-1065/
Daily: '19 Frontier 4WD Belle: '67 Belvedere Convertible, 318/727 in Go ManGo! Other: '64 C10, 283/3 on the tree
[Re: jerseybud]
#1318098
10/10/12 01:53 PM
10/10/12 01:53 PM
Posts: 64 Iowa
GreenBird
Iowa
Yes, they are. terrysautolab.com
It was in the Aug 2012 Mopar action.
I am using this on my RB engine and it works great.
