Why do I even bother with these aftermarket.....!!!! #1318081
10/09/12 10:10 PM
10/09/12 10:10 PM
N.E. Ohio
K
KillerBee Offline OP
K
N.E. Ohio
Big block thermostat housings.
Fired up the 440 Sixpack for the first time in the 71 R/T Challenger.
All in all eveything went very well.
The carbs reminded me that you always need to check for leaks at the fuel lines, but that was a quick and easy fix.
Ran the engine, got the timing set and everything sounded great(especially with open headers)
Ran it for awhile to get some temp in it.
The engine has always ran very cool so it took awhile to get it warm, I thought I was in the clear with any leaks...then I noticed coolant weeping under the rear of the the housing.
Tried to tighten the bolts down but I don't think that will work.
It's the thick Milidon housing that some have had success with.
I used a new gasket with some Indian Head shellac for sealer...maybe that was my mistake.
I've NEVER had any luck with these POS aftermarket housings.
So I'm very happy with everything except the housing...I should have known better.
It sure was nice to DRIVE the car into the garage instead of pushing it like I've done for soo many years.
So time to drain the coolant and try again.
I'm not sure if I'm gonna try to seal it or go back to my tried and true stock housing.
Any suggestions?
Re: Why do I even bother with these aftermarket.....!!!! [Re: KillerBee] #1318082
10/09/12 10:23 PM
10/09/12 10:23 PM
Any suggestions?
with it clamped upside down with a rag in a vise, drawfile it to remove the chrome/level the gasket surface. Might drawfile the stat neck on the pump housing also (put a rag inside to keep filings out) but very likely the issue is the chrome itself on the stat housing & less likely is it being slightly warped, just not completely flat but drawfiling takes care of both. The sides and top (that you can see) will still be shiney chrome so all is good in the 'hood
Re: Why do I even bother with these aftermarket.....!!!! [Re: RapidRobert] #1318083
10/09/12 10:52 PM
10/09/12 10:52 PM
IN
ahy Offline
ahy  Offline
IN
I had one of those chrome versions and it leaked. I machined it flat on a belt sander and got it to seal for a little while and it leaked again. Best to throw the `chrome ones in the garbage. What worked for me:
- parts store iron water neck (or billet aluminum Mancini is supposed to be good)
- check for flatness and smooth if necessary. I touched up my new water neck on the belt sander
- install with a gasket and permatex #1... the hardening kind
- torque gently. too much torque will bend the housing and cause a leak
The iron water necks are inexpensive. With a coat of engine enamal they look fine. I have had zero problems for several years after doing the above.
Re: Why do I even bother with these aftermarket.....!!!! [Re: RapidRobert] #1318084
10/09/12 10:54 PM
10/09/12 10:54 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Any suggestions?
I just went through exactly the same thing with mine. If you take it off, I'm sure you will see that it is warped (bent down at the ends and up in the middle. The more you tighten it, the worse it gets. You can grind/file it flat and it will do it again. This has happened to me too many times. They are all crap. Do yourself a favor. Chuck it in the trash and use the OEM one.
Re: Why do I even bother with these aftermarket.....!!!! [Re: bobs66440] #1318085
10/09/12 10:58 PM
10/09/12 10:58 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
I believe someone now making one with an o-ring seal.
Re: Why do I even bother with these aftermarket.....!!!! [Re: rss] #1318086
10/09/12 11:03 PM
10/09/12 11:03 PM
jersey
Spaceman Spiff Offline
jersey
I'm using this. Hasn't wept a drop since putting it on 7,000+ miles ago.
http://www.summitracing.com/parts/BSP-90820/
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Why do I even bother with these aftermarket.....!!!! [Re: rss] #1318087
10/09/12 11:03 PM
10/09/12 11:03 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Yes, they are.
terrysautolab.com
It was in the Aug 2012 Mopar action.
Re: Why do I even bother with these aftermarket.....!!!! [Re: rss] #1318088
10/09/12 11:06 PM
10/09/12 11:06 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Chevy ones are the same so there's plenty out there to choose from.
Re: Why do I even bother with these aftermarket.....!!!! [Re: jerseybud] #1318089
10/09/12 11:13 PM
10/09/12 11:13 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
I'm using a housing made by Billet Specialties on my 440 and have never had a leak. Part number is 90820. Very nice piece with the O ring it is an easy sealing housing.
Re: Why do I even bother with these aftermarket.....!!!! [Re: RBSat66] #1318090
10/09/12 11:59 PM
10/09/12 11:59 PM
Detroit Michigan
stinger Offline
stinger  Offline
Detroit Michigan
bought a 440 source billet,works great.chrome is to hard to seal.
Re: Why do I even bother with these aftermarket.....!!!! [Re: stinger] #1318091
10/10/12 12:04 AM
10/10/12 12:04 AM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
same BS here!!!
Re: Why do I even bother with these aftermarket.....!!!! [Re: KillerBee] #1318092
10/10/12 01:38 AM
10/10/12 01:38 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I got 2 of the newer Milidon chrome necks in use, neither one leaks, I've had some of the older necks, that were just junk, and a few with no issues over the years, I have an old CalCustom on my Challenger T/A...it's been on for about 30 yrs now!, and still looks good
...anyway, recently installed one (Milidon) in my kids Dodge truck, toss the gasket supplied, use a Duralast gasket (Autozone/parts store) PN# 35063 it's a lot thicker, install the gasket first using a film of Permatex Gold engine sealant under the gasket, after gasket install, add another film of Permatex Gold, then install the thermostat, then add the housing, tighten to spec evenly, should be ready to add coolant in about 1 hr...I've seen some guys put the thermostat down first then the gasket over it, that's an issue too,..plus that Indian head sealer some like to use is problematic as well, as well as form-a-gasket
Mike
Re: Why do I even bother with these aftermarket.....!!!! [Re: DAYCLONA] #1318093
10/10/12 01:42 AM
10/10/12 01:42 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I've always used the stock neck and never had an issue. Another case of If it's not broke don't fix it.
Re: Why do I even bother with these aftermarket.....!!!! [Re: KillerBee] #1318094
10/10/12 08:09 AM
10/10/12 08:09 AM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
FWIW: When I first assembled my engine I too read all about leaky chrome housings. I stepped up and bought the Mancini piece. Never touched it again in 4 years.
`68 Barracuda 340-S
Re: Why do I even bother with these aftermarket.....!!!! [Re: DaytonaTurbo] #1318095
10/10/12 09:59 AM
10/10/12 09:59 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
BINGO!!!!
I always use a stock neck.
Re: Why do I even bother with these aftermarket.....!!!! [Re: Commando1] #1318096
10/10/12 10:17 AM
10/10/12 10:17 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Hard to seal anything against chrome.
Like RapidRobert says, a big O' file is your friend. I file old originals back to a nice flat, smooth surface. Removing chrome for a good seal is a must to me.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Why do I even bother with these aftermarket.....!!!! [Re: moparmarks] #1318097
10/10/12 01:25 PM
10/10/12 01:25 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
Didn't get mine from Summit, but I'm running an SS one on my 318.
http://www.summitracing.com/parts/PRS-1065/
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Why do I even bother with these aftermarket.....!!!! [Re: jerseybud] #1318098
10/10/12 01:53 PM
10/10/12 01:53 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
Yes, they are.
terrysautolab.com
I am using this on my RB engine and it works great.
Re: Why do I even bother with these aftermarket.....!!!! [Re: GreenBird] #1318099
10/10/12 03:35 PM
10/10/12 03:35 PM
dogdays Offline
dogdays  Offline
I am using The Right Stuff instead of a gasket, works perfectly.
R.
Re: Why do I even bother with these aftermarket.....!!!! [Re: RBSat66] #1318100
10/10/12 07:01 PM
10/10/12 07:01 PM
Canada
CrAzYMoPaRGuY Offline
Canada
I've got the very same one on my Charger. LEAK FREE! I was astounded!
CrAzYMoPaRGuY
