removing a 1970 roadrunner dash frame
#131718
10/03/08 06:48 PM
10/03/08 06:48 PM
Hi, I have a 1970 Roadrunner and i'm not sure if the dash frame is removal or not? The reason I need to remove the frame so I can paint the top of the dash. Please help, thanks. ![](/ubbthreads/images/graemlins/smilie_help.gif)
Re: removing a 1970 roadrunner dash frame
[Re: superwrench]
#131720
10/03/08 07:01 PM
10/03/08 07:01 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Correct.Windshield has to be removed,and the dash frame bolts are under the seal.
[Re: superwrench]
#131721
10/03/08 07:03 PM
10/03/08 07:03 PM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
The windshield must be removed to access the bolts under the gasket. Remove those bolts and one bolt on each corner of the dash behind the kick panels and it will come out. The A pillar moldings and steering column will also need to be taken loose. ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
