removing a 1970 roadrunner dash frame #131718
10/03/08 07:48 PM
10/03/08 07:48 PM
Anonymous OP
Anonymous OP
Hi, I have a 1970 Roadrunner and i'm not sure if the dash frame is removal or not? The reason I need to remove the frame so I can paint the top of the dash. Please help, thanks.
Re: removing a 1970 roadrunner dash frame #131719
10/03/08 07:52 PM
10/03/08 07:52 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Windshield has to come out first I believe.
Re: removing a 1970 roadrunner dash frame [Re: superwrench] #131720
10/03/08 08:01 PM
10/03/08 08:01 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Correct.Windshield has to be removed,and the dash frame bolts are under the seal.
Nautilus Racing-
Re: removing a 1970 roadrunner dash frame [Re: superwrench] #131721
10/03/08 08:03 PM
10/03/08 08:03 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
The windshield must be removed to access the bolts under the gasket.
Remove those bolts and one bolt on each corner of the dash behind the kick panels and it will come out.
The A pillar moldings and steering column will also need to be taken loose.
Re: removing a 1970 roadrunner dash frame [Re: sthemi] #131722
10/03/08 08:23 PM
10/03/08 08:23 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Big Block,
If you can, make a small stand to hold the dash frame while you paint it. Let it cure and use the same stand to assemble the components and reinstall it as a complete assembly back into the car. It made my work much easier!
68 Hemi Road Runner
Re: removing a 1970 roadrunner dash frame [Re: 68jim] #131723
10/03/08 08:25 PM
10/03/08 08:25 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
After paint...
Re: removing a 1970 roadrunner dash frame [Re: 68jim] #131724
10/03/08 08:26 PM
10/03/08 08:26 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Reassembled...
Re: removing a 1970 roadrunner dash frame [Re: 68jim] #131725
10/03/08 08:28 PM
10/03/08 08:28 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Installed...
Good Luck!
Re: removing a 1970 roadrunner dash frame [Re: 68jim] #131726
10/03/08 09:48 PM
10/03/08 09:48 PM
superwrench Offline
superwrench  Offline
AAA-H-H-H-......that looks like nice work 68jim
Just going thru that with my 68 GTX...hope it looks as nice!
Re: removing a 1970 roadrunner dash frame [Re: superwrench] #131727
10/04/08 10:03 AM
10/04/08 10:03 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
One more with the rest of the interior.
Re: removing a 1970 roadrunner dash frame [Re: 68jim] #131728
10/04/08 12:27 PM
10/04/08 12:27 PM
So Cal, USA
Fab64 Offline
Fab64  Offline
So Cal, USA
Man, that's beautiful.
