Re: Ring compressor recomendations
[Re: jamesc]
#1317080
10/08/12 06:05 AM
10/08/12 06:05 AM
Posts: 6,295 U.S.
moparniac
U.S.
I have total seal and is adjustable.
Mopar Performance
[Re: 440Jim]
#1317084
10/08/12 11:21 AM
10/08/12 11:21 AM
Posts: 7,506 Az
Crizila
Az
On E-bay or Racers Outlet - "PRC" #41-4000-kit = $87.99 and consists of 4 tapered compressors (4", 4.030", 4.040", and 4.060".
Fastest 300
[Re: Crizila]
#1317088
10/08/12 12:17 PM
10/08/12 12:17 PM
Posts: 252 Seattle, WA.
edp
Seattle, WA.
thanks guys, thats quite a list!
I figured the tapered one would be what I end up with. If stock pistons are 4.250 (I think - should measure) & mine are .030 over I assume I need the 4.280 tapered or do you want one slightly larger than the oversized piston?
Oh yeah, going in a 69 383 HP motor, badger 10:1 pistons.
Thx. E
[Re: 440Jim]
#1317090
10/08/12 12:56 PM
10/08/12 12:56 PM
Posts: 5,875 communist bloc of new jersey
jamesc
The tapered ring compressors are so nice and easy to use. Broken rings are a thing of the past. Think of it as a cost of building the motor. And a tool you will have for the rest of your life. Including any future rebuilds. ![](/ubbthreads/images/graemlins/Twocents.gif)
If you do a lot of different size motors/pistons, then the locking pliers type with several bands are the next best thing.
http://www.summitracing.com/parts/ARP-900-3750/
http://www.bing.com/shopping/alltrade-94...r&FORM=HURE
this is the point i was trying to make
the tapered compressors are great but when i worked in an engine rebuilding shop it was not practical and the plier type will work decent you just need to be careful. we used to upset the bottom of the band with a pair of dykes so there was a little part sticking out to keep the band from wanting to go into the bore which was the biggest problem i ever saw with them. come to think of it of they would just spotweld a little nub on them it would be great
