Ring compressor recomendations #1317078
10/08/12 02:22 AM
10/08/12 02:22 AM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
As the title suggests - whats a really good one or type? I've got a crappy conventional one that worked OK on Datsun 76mm pistons but is sh**y on 4.25" pistons.
the tapered ones look pretty decent, not east to find local though..
thanks, Evan
Re: Ring compressor recomendations [Re: edp] #1317079
10/08/12 02:26 AM
10/08/12 02:26 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
it depends on what you want. tapered is by far the best, there is also the split tapered though i've never used them so i don't know what the range is. the plier type can have a big range and work ok as long as you're careful
as for finding local you could order any of them online
Re: Ring compressor recomendations [Re: jamesc] #1317080
10/08/12 06:05 AM
10/08/12 06:05 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I have total seal and is adjustable.
Mopar Performance
Re: Ring compressor recomendations [Re: jamesc] #1317081
10/08/12 07:25 AM
10/08/12 07:25 AM
Az
Crizila Offline
Crizila  Offline
Az
Save yourself some grief and go tapered. You can get them pretty reasonable on E-bag. Think I bought a set of 4 ( along with a ring squaring tool ) for around $120.
Fastest 300
Re: Ring compressor recomendations [Re: edp] #1317082
10/08/12 07:33 AM
10/08/12 07:33 AM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
I bought the proper sized fixed style and love it.
Goodvibe Racing
Re: Ring compressor recomendations [Re: edp] #1317083
10/08/12 10:56 AM
10/08/12 10:56 AM
NC
440Jim Offline
440Jim  Offline
NC
The tapered ring compressors are so nice and easy to use. Broken rings are a thing of the past. Think of it as a cost of building the motor. And a tool you will have for the rest of your life. Including any future rebuilds.
If you do a lot of different size motors/pistons, then the locking pliers type with several bands are the next best thing.
http://www.summitracing.com/parts/ARP-900-3750/
http://www.bing.com/shopping/alltrade-94...r&FORM=HURE
Re: Ring compressor recomendations [Re: 440Jim] #1317084
10/08/12 11:21 AM
10/08/12 11:21 AM
Az
Crizila Offline
Crizila  Offline
Az
On E-bay or Racers Outlet - "PRC" #41-4000-kit = $87.99 and consists of 4 tapered compressors (4", 4.030", 4.040", and 4.060".
Fastest 300
Re: Ring compressor recomendations [Re: edp] #1317085
10/08/12 11:57 AM
10/08/12 11:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This is the style I use... it gives you a small bit
of adjustment so if I bore the engine it will still
work(this isnt the size I use but the same thing)...
it is the tapper style
http://www.summitracing.com/parts/SME-90A3900/
Re: Ring compressor recomendations [Re: Crizila] #1317086
10/08/12 11:58 AM
10/08/12 11:58 AM
Renton Washington
Triple Threat Offline
Renton Washington
I purchased a Summit brand adjustable tapered compressor for my last engine build. I was very pleased with it. Much much nicer than the cheap band style.
http://www.summitracing.com/search/Part-...ing+compressors
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Ring compressor recomendations [Re: MR_P_BODY] #1317087
10/08/12 12:00 PM
10/08/12 12:00 PM
Az
Crizila Offline
Crizila  Offline
Az
The taper plus adjustability thing is nice.
Fastest 300
Re: Ring compressor recomendations [Re: Crizila] #1317088
10/08/12 12:17 PM
10/08/12 12:17 PM
Seattle, WA.
E
edp Offline OP
edp  Offline OP
E
Seattle, WA.
thanks guys, thats quite a list!
I figured the tapered one would be what I end up with. If stock pistons are 4.250 (I think - should measure) & mine are .030 over I assume I need the 4.280 tapered or do you want one slightly larger than the oversized piston?
Oh yeah, going in a 69 383 HP motor, badger 10:1 pistons.
Thx. E
Re: Ring compressor recomendations [Re: edp] #1317089
10/08/12 12:20 PM
10/08/12 12:20 PM
Renton Washington
Renton Washington
Get one intended for the bore size you will end up with, 4.28 in your case.
http://www.summitracing.com/parts/SME-90A4250/
-Dustin
Re: Ring compressor recomendations [Re: 440Jim] #1317090
10/08/12 12:56 PM
10/08/12 12:56 PM
jamesc Offline
jamesc  Offline
this is the point i was trying to make
the tapered compressors are great but when i worked in an engine rebuilding shop it was not practical and the plier type will work decent you just need to be careful. we used to upset the bottom of the band with a pair of dykes so there was a little part sticking out to keep the band from wanting to go into the bore which was the biggest problem i ever saw with them. come to think of it of they would just spotweld a little nub on them it would be great
