Re: s/s springs without pinion snubber ?
[Re: junkyardmaxie]
#1316596
10/07/12 01:23 PM
10/07/12 01:23 PM
Posts: 1,532 off the grid
340B5
off the grid
A lot of S/S racers will tell you to ditch the snubber. Just clamp the heck out of the front of the spring leaves and leave the factory ones on the back.
Yeah, it's got a smallblock.
[Re: junkyardmaxie]
#1316597
10/07/12 01:27 PM
10/07/12 01:27 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i have used a truck dana housing in my car,with s/s springs ,no place to bolt the snubber.has anyone ever run one without a snubber ? what degree is the pinion angle set at ? thanks
A pinion snubber was a band-aid to cover up bad springs so if your springs are good you wont need it... for racing set the pinion 5-7... if its a street car that might see the track go less... about 4*
[Re: 340B5]
#1316599
10/07/12 01:37 PM
10/07/12 01:37 PM
Posts: 854 Bloomingdale , OH
super451b
Bloomingdale , OH
I ran 3400# SS springs with 5* of pinion angle.
[Re: super451b]
#1316600
10/07/12 02:18 PM
10/07/12 02:18 PM
Posts: 3,210 robin hood country
deaks
robin hood country
I run a Dana, SS springs clamped on the front sections, no snubber, 6 degrees nose down. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: junkyardmaxie]
#1316602
10/07/12 04:12 PM
10/07/12 04:12 PM
MR_P_BODY
when you clamp the front part of spring, where do you locate the clamps in relation ship to the fornt spring eye let bolt ? thanks
Clamp each leaf about 2"-3" behind the end of the leaf
