s/s springs without pinion snubber ? #1316595
10/07/12 01:14 PM
10/07/12 01:14 PM
OH
junkyardmaxie Offline OP
OH
i have used a truck dana housing in my car,with s/s springs ,no place to bolt the snubber.has anyone ever run one without a snubber ? what degree is the pinion angle set at ? thanks
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316596
10/07/12 01:23 PM
10/07/12 01:23 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
A lot of S/S racers will tell you to ditch the snubber. Just clamp the heck out of the front of the spring leaves and leave the factory ones on the back.
Yeah, it's got a smallblock.
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316597
10/07/12 01:27 PM
10/07/12 01:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A pinion snubber was a band-aid to cover up bad springs
so if your springs are good you wont need it... for
racing set the pinion 5-7... if its a street car that
might see the track go less... about 4*
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316598
10/07/12 01:29 PM
10/07/12 01:29 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
mine was 4-5 deg down.
Re: s/s springs without pinion snubber ? [Re: 340B5] #1316599
10/07/12 01:37 PM
10/07/12 01:37 PM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
I ran 3400# SS springs with 5* of pinion angle.
Re: s/s springs without pinion snubber ? [Re: super451b] #1316600
10/07/12 02:18 PM
10/07/12 02:18 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I run a Dana, SS springs clamped on the front sections, no snubber, 6 degrees nose down.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316601
10/07/12 03:01 PM
10/07/12 03:01 PM
OH
OH
when you clamp the front part of spring, where do you locate the clamps in relation ship to the fornt spring eye let bolt ? thanks
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316602
10/07/12 04:12 PM
10/07/12 04:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Clamp each leaf about 2"-3" behind the end of the leaf
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316603
10/07/12 04:13 PM
10/07/12 04:13 PM
I use to clamp every leaf I could at the front of that leaf to the main leaf I did end up staggering the rear clamps behind the rear end housing, I ended up leaving the drivers side rear clamp in the stock location and moved the pasenger side up so it was back about the second leaf from the bottom of the stack on the 002 and 003 SS springs, that made the car leave level on the front end foot braking instead of the drivers side being all twisted up Make sure your rear shackle angle is good, not pointed straight down or angle rearwards from the rear spring eye when sitting still in nuetral
Re: s/s springs without pinion snubber ? [Re: Cab_Burge] #1316604
10/07/12 04:34 PM
10/07/12 04:34 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just use the 3400 lb SS springs also with no snubber. Ron
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316605
10/07/12 06:34 PM
10/07/12 06:34 PM
OH
OH
thanks for the help
Re: s/s springs without pinion snubber ? [Re: junkyardmaxie] #1316606
10/07/12 06:51 PM
10/07/12 06:51 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Never ran a snubber when I ran SS springs......just clamped the front and 5 degrees.
