Re: New Best........ But
[Re: EDDIEB]
#1316322
10/06/12 06:50 PM
10/06/12 06:50 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Was it the same track? Some tracks are faster than others(up/down hill, clocks)
Was the air really better or was it just a little cooler? Barometric pres., humidity make a big difference
Congrats on the new best
"Just a Bracket car dressed up like a streetcar"
[Re: Just-a-dart]
#1316323
10/06/12 07:46 PM
10/06/12 07:46 PM
Posts: 3,210 robin hood country
deaks
robin hood country
HI Eddie Congrats on the new best, i was wondering yesterday if you'd ran the car since the head upgrade. How did your 60fts compare to last time out. I wouldn't have thought that amount would make much diffence, unless you had the lash way too tight. I run my .590 at .022 all round cold lash. Did you do a plug check or try jetting the car up for the cooler air. Post the incrementals of one of your tickets up. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Just-a-dart]
#1316328
10/07/12 10:19 PM
10/07/12 10:19 PM
Posts: 43,305 Bend,OR USA
Cab_Burge
I've seen this happen to freinds in the past, they made changes to the car and motor and didn't pick up the 1/4 ET and MPH, ended up they where running out of fuel in the last two to three hunded feet. No missing or any other indication that it was running out of fuel other than not pulling hard the last part of the track It has happen to me in so many ways(pump size, fuel line size, needle and seat size. fuel element to fine and the list goes on ) it makes me want Try jetting the carb. up 2 or 3 jet sizes and see if that helps or hurts the ET and MPH, if it doesn't change either the ET or MPH fix the fuel delivery problem, or problems Let us know what you find out
