is this hood correct? #1316133
10/06/12 09:06 AM
10/06/12 09:06 AM
Dallas
citadel Offline OP
citadel  Offline OP
Dallas
The previous owner claims it is an original hood however it doesnt have the air vent cut outs in the recessed area
1969 roadrunner
build date 3/14/1969
non airgrabber
Re: is this hood correct? [Re: citadel] #1316134
10/06/12 09:20 AM
10/06/12 09:20 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
Yes, thats an original hood, for a 68! Once the fresh air hood option was available, odds are that they were all cut out. Your build date seems too late, I would say that hood was replaced.
Re: is this hood correct? [Re: Bull1tt] #1316135
10/06/12 12:04 PM
10/06/12 12:04 PM
Dallas
citadel Offline OP
citadel  Offline OP
Dallas
I have the ICCA book at it shows 3 version of the hoods from 1968-1969.
Verison #1 was for early 68 cars and different bracing
Version #2 was for late 68 cars and seems to be what I have on my 69 built in 3/1969
Version #3 had the cut outs for the air grabber option.
What is the chance that the hood I have came as original for the factory. I am asking because we are building a correct as built restoration and I am trying to decide if I need to get a different hood. I would hate to spend the money as this hood is in good shape and was advertised as being correct.
The pic attached shows the car before we began the restoration/ blasting.
thoughts?
Re: is this hood correct? [Re: citadel] #1316136
10/06/12 02:05 PM
10/06/12 02:05 PM
connecticut
pnypwr Offline
pnypwr  Offline
connecticut
thats a late 68 or early 69 hood...not sure of the cut date but id say its not correct as 3 69 is later production and would have the cut outs...that looks like a nice hood...i need a clean 68 hood for my car...somebody cut the vents out poorly on mine
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
Re: is this hood correct? [Re: pnypwr] #1316137
10/06/12 04:46 PM
10/06/12 04:46 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
Was the Air Grabber option available on the very first 1969 production? I thought it was?
Re: is this hood correct? [Re: A12] #1316138
10/06/12 06:10 PM
10/06/12 06:10 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Forget the hood, let's discuss that color
Re: is this hood correct? [Re: ScottSmith_Harms] #1316139
10/06/12 06:19 PM
10/06/12 06:19 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
All of my '69s were cut open where the bezels bolt on, whether air-grabber or not. None of my '68s were/are cut open there. I'm referring to the outer panel.
Most of my '69 RRs were mid-run production dates, but my '68s varied from 9/67 (still have that one) through late April '68.
Re: is this hood correct? [Re: topside] #1316140
10/06/12 07:24 PM
10/06/12 07:24 PM
Dallas
citadel Offline OP
citadel  Offline OP
Dallas
yes the previous owner painted it Y1. We are going back to the original Y2- Sunfire.
Re: is this hood correct? [Re: ScottSmith_Harms] #1316141
10/06/12 11:07 PM
10/06/12 11:07 PM
N.E. OHIO, USA
A12 Online content
A12  Online Content
N.E. OHIO, USA
If the Air Grabber was available from the very first 1969 rr or GTX then ALL 1969 rr/GTX would have to have the cut-out hood openings. My Dec 16, 1968 SPD GTX has the cut-outs but no Air Grabber. That would make that hood a '68 hood regardless of SPD early or late.
Re: is this hood correct? [Re: A12] #1316142
10/07/12 10:27 AM
10/07/12 10:27 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Do the brace and skin have the cut out on your hood? or just the brace? I haven't looked at a very early 69 hood, but early 68's have the no cuts in the brace or hood, later 68, starting as early as 3/68 from what I have seen on org cars, has the brace cut like a 69 air grabber but no cuts in the skin. All the 69's I have seen have the brace and skin cut.
Early 68 hood
Re: is this hood correct? [Re: rrunner] #1316143
10/07/12 10:29 AM
10/07/12 10:29 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Late 68 hood
Re: is this hood correct? [Re: rrunner] #1316144
10/07/12 10:35 AM
10/07/12 10:35 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
69 hood
has the same brace as a late 68 but has the cut outs in the skin. As far as I know all 69's are like this.
Re: is this hood correct? [Re: rrunner] #1316145
10/07/12 10:53 AM
10/07/12 10:53 AM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Also notice the small cuts in the skin of the yellow hood, this has to be done to fit 69 inserts in to a 68 hood as the insert retainer screws for the grill will not allow the 69 insert to fit flush with the skin.
Re: is this hood correct? [Re: rrunner] #1316146
10/07/12 05:24 PM
10/07/12 05:24 PM
Dallas
citadel Offline OP
citadel  Offline OP
Dallas
based on those pics with match the ICCA book I have, the hood I have looks to be a late 68 hood. Those small cut outs you circled are from the factory I think.. thoughtd?
Re: is this hood correct? [Re: citadel] #1316147
10/07/12 07:05 PM
10/07/12 07:05 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
Yes, your hood is a late 68 and those cuts I circled are not factory, someone did that to install 69 inserts in a 68 hood. All you have to do to make that hood a correct 69 hood is cut the skin like the picture I posted of the 69 hood.
