5.9 mag in an a-body #1315887
10/05/12 04:32 PM
10/05/12 04:32 PM
Missouri
Clayton Offline OP
Clayton  Offline OP
Missouri
Im going to put a 5.9 mag motor in my 67 barracuda and since im going to keep the serpintine belt set up Ive been told I need the power sreering bracket from a van or grand cherokee. Does anyone know what year of van or cherokee the bracket needs to be? Thanks, Clay
Re: 5.9 mag in an a-body [Re: Clayton] #1315888
10/05/12 05:08 PM
10/05/12 05:08 PM
Andrewh Offline
Andrewh  Offline
just any ram van with a magnum worked. never tried the one from a jeep, not sure how easy that would be to find.
there is a catch. I have a post on it somewhere.
the belt that the original mag used won't work, and the van one doesn't quite work unless you replace the idler pully too.
turns out the van setup uses a different a/c pulley, and it throws off the whole setup if you try to use a truck mag with a van ps pump.
so I found the 5.7 hemi idler pulley is smaller and is a direct swap out for the idler on the truck 5.9 and brings the pulley sizes in line so you can use a standard belt.
here is my post on the issue.
https://board.moparts.org/ubbthreads/show...rue#Post7329831
Re: 5.9 mag in an a-body [Re: Clayton] #1315889
10/05/12 06:16 PM
10/05/12 06:16 PM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
I'm doing the same 2001 Durango 5.9 swap in a '68 a-body.
What exactly is the issue with the Durango power steering pump with the stock serpentine belt configuration?
What does it hit or get in the way of?
Does it matter if the battery is moved to the trunk.
Re: 5.9 mag in an a-body [Re: jbc426] #1315890
10/05/12 06:33 PM
10/05/12 06:33 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
if you move battery to trunk then the durango should work
Re: 5.9 mag in an a-body [Re: jbc426] #1315891
10/05/12 06:33 PM
10/05/12 06:33 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
I used entire setup from a 94 van (alt, AC, power steering) it fit fine.
1970 Challenger T/A
1970 Roadrunner RM21 Vcode
1971 Gtx
1971 Satellite
1971 Charger 500 GB5 383 A54 car
1972 Satellite
1997 Dodge 1500 hunting rig
2014 Ram 2500 Mega Cab
Re: 5.9 mag in an a-body [Re: mdwyer] #1315892
10/05/12 06:34 PM
10/05/12 06:34 PM
Carlisle, AR.
mdwyer Offline
mdwyer  Offline
Carlisle, AR.
in car pic THere is room next to battery tray but not alot. Dakota / Ram pw steering bracket tries to mate with the battery tray.
mike
1970 Challenger T/A
1971 Gtx
1971 Satellite
1972 Satellite
Re: 5.9 mag in an a-body [Re: mdwyer] #1315893
10/05/12 08:26 PM
10/05/12 08:26 PM
Andrewh Offline
Andrewh  Offline
in a b body using the durango one puts the ps pump under the battery tray. can't ever fill it.
using the van one, it tucks it down and back in a little.
Re: 5.9 mag in an a-body [Re: Clayton] #1315894
10/05/12 09:58 PM
10/05/12 09:58 PM
Harm City Md.
Dan Halen Offline
Dan Halen  Offline
Harm City Md.
Grand Cherokee pump sits relatively high and uses a bracket and spacer
that bolts to the cylinder head. You'll probably want to use the pump
too as it's different than the trucks.
