affordable & streetable smallblock solid roller lifters
#1315456
10/05/12 12:12 AM
10/05/12 12:12 AM
Posts: 3,415 Toronto
mshred
Toronto
So I have been doing some thinking about cam setups for my current motor since it is apart again. I have been giving some thought into a solid roller setup, and I know it is definitely a price jump from the solid flat tappet stuff...I drive my car quite a bit on the street (3-4000 miles a year), and have thought about whether a solid roller would fit my application? My biggest concern is the lifters- I have seem some mention lifters from PBM, Morel, or Chet Herbert for 300 dollars and under, but on the same note have heard mention that lifters that are not HIPO oiling or don't oil the rollers constantly are no good to use on the street. So my question becomes what brands of lifters would accomplish what i am looking to do on the street? (as obviously they should work great at the track) What are the prices and features of these lifters? I know many would say just pony up the money once for the solid roller, but at this point in time, I just can't afford a set of $500+ roller lifters, plus the springs, retainers and keepers to match, and then the cam itself. If there is something out there that works for cheaper, I am all for it though. Curious to hear your opinions and experiences with this stuff
Re: affordable & streetable smallblock solid roller lifters
[Re: mshred]
#1315457
10/05/12 12:26 AM
10/05/12 12:26 AM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
Honestly, running on the street and racing it( I did the same while back with pretty big roller) the last place I would try to cut is on roller lifters I pushrods oiled and used crane ultra pro's. Super nice pieces. Maybe others will have different thoughts, but I like doing stuff once, and not wondering
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Chris'sBarracuda]
#1315460
10/05/12 07:21 AM
10/05/12 07:21 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
After four races my Comps were junk. Will not do that again.
Get you a set of Morrels. Bullit Cams sells them with their name on them. Crower is a good lifter also. Get the EDM option if you can.
#1315462
10/05/12 10:52 AM
10/05/12 10:52 AM
mshred
Toronto
Didn't Brian IMM Engines (ou812) help design a small block lifter for Comp??
Maybe you should be asking him..
Chris..
Yes I am aware of that. Brian just had a kid and told me he wasn't going to be in the shop as much. I was going to call him next week and get his opinion on this as well. I was just kinda thinking out loud with this thread to what luck others are having
I'm just wondering what the differences between the cheaper lifters and more expensive ones were as well
[Re: Leon441]
#1315463
10/05/12 10:54 AM
10/05/12 10:54 AM
mshred
Toronto
Hey Leon what is edm? Aren't the morels the more affordable ones that don't oil as well? Or am I completely wrong?
[Re: rickraw]
#1315464
10/05/12 10:55 AM
10/05/12 10:55 AM
mshred
Toronto
same here. i went with gsp rollers. saw some members on run them, so i gave them a shot. i run a offset intake(w9"s), 760$ delivered. standard rollers maybe cheaper?? if i ever have to do it over, i'm changing to a plain solid lifter, won't have to worry about losing a roller.
Rick did you have a roller fail on you?
[Re: mshred]
#1315465
10/05/12 11:33 AM
10/05/12 11:33 AM
Posts: 9,876 Weddington, N.C.
Streetwize
Weddington, N.C.
Morels are good Solid lifters, Doug Herbert sells them very reasonably. The body seems to be a good bit longer than other brands so the pushrod winds up being shorter (i.e. stiffer for a given cross section) which should be theoretically advantageous....though less so on a 59 degree valley angle (increases the pushrod arc). I've spun my 414 to about 7200....so far.
[Re: Streetwize]
#1315467
10/05/12 12:30 PM
10/05/12 12:30 PM
mshred
Toronto
Wize those are the lifters I was looking at. Previous posts on here said they were reasonably priced around $300 but my question is are they sufficient for lots of street miles based on their design and oiling characteristics compared tomorro expensive lifters?
[Re: pittsburghracer]
#1315468
10/05/12 12:37 PM
10/05/12 12:37 PM
mshred
Toronto
How fast do you plan on going that you feel the need for a roller cam? A solid cam will fill the needs for most.
Not that fast at all really, high tens on the gas most likely. It's just that's know they make more power and the fact that they are a roller wheel instead of a flat tappet just gives me a little more price of mind. Even though I ran good oil in my other motors just because I wanted to, I never had to worry about ever losing a lobe because if a lifter ( hydraulic rollers). That said I know asolidflattappet will be fine, I was just thinking about the roller since I am in the process of changing things and now would be the ideal time
[Re: mshred]
#1315469
10/05/12 12:47 PM
10/05/12 12:47 PM
Streetwize
Weddington, N.C.
I run the (#2 and #4) grooved cam journals for continuous oiling and massage the drainback channels in the heads to make sure I get plenty of drainage back to the valley. Mine's a bracket car though but I think they're fine for a reasonable spring pressure moderate RPM motor like most strokers. There may be better choices out there but these seem more than up to the job I'm throwing at them. The word I've heard about the Morel/Bullet design is they are essentially the same body as the Hydraulic Roller lifters converted to solids(which would explain the larger body/shorter pushrod), they seem to do really well.
[Re: Streetwize]
#1315470
10/05/12 12:50 PM
10/05/12 12:50 PM
B3422W5
Portage,michigan
Wize...any clearancing for the tie bars, or did they drop right in?
[Re: B3422W5]
#1315472
10/05/12 01:13 PM
10/05/12 01:13 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I run the comp 828s in my SB. I don't have any oiling to the lifters and full time oil to the rockers. So far they have about 2500 miles on them. I won't lie though, I just got off dragweek and that was my biggest concern. For the first few hundred miles every noise I heard was a lifter wheel coming off (in my mind)
68 Barracuda Formula S 340
[Re: mshred]
#1315473
10/05/12 01:42 PM
10/05/12 01:42 PM
Posts: 4,209 New York
polyspheric
New York
2 things to avoid with roller tappets:
Not enough spring pressure; even if you keep the RPM down don't go below the manufacturer's load
Loose valve lash. Eventually, the axle bearings fail, and the [CRASH] as they hit the closing side and bounce is very destructive, especially at idle. This is what "rev kits" are made for.
Boffin Emeritus
