22" radiator support + 440 = I need a radiator, help!!!
#131492
10/03/08 02:45 AM
10/03/08 02:45 AM
Posts: 18 Salem, OR USA
uh60lbhawk
Salem, OR USA
Ok, I'm restoring/building a 69 charger. It was originally a 318 car. Now it has a 440. When I bought it, it had the 22 inch radiator, and would get hot if you stopped in traffic for any lenght of time, especially if it was a hot day. The bodywork is done, and the car is currently being painted, including the radiator support. Repalcing/changing the support is not an option for me at this point. I am running a stock style clutch fan, and want to use a shroud, thus it would be better to have something with near stock dimensions so that a stock shroud will fit. Where can I get a 3 or 4 core copper 22 inch radiator that will "bolt in"? Or, are there other options? $500.00 plus is not an option either, I just chucked over $20,000 into body/paint. I'm basically broke, and I'm deploying overseas sometime after new years. I really want to get this car to the point that I can at least take it for one drive before I park it in the garage until 2010! (yeah, I know, it sucks!) Thanks, Clint ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
Re: 22" radiator support + 440 = I need a radiator, help!!!
[Re: uh60lbhawk]
#131494
10/03/08 02:59 AM
10/03/08 02:59 AM
Posts: 216 united kingdom
Simonic
united kingdom
hi, I run a 500ci in my 68 superbee. i also use the 22in rad. i had a new core put into the the rad which had more cores in it. I also use a shroud. cheers
Keeping the Bee Buzzin'
[Re: HEMICUDA]
#131495
10/03/08 03:03 AM
10/03/08 03:03 AM
uh60lbhawk
Salem, OR USA
Unforunately, I no longer have the original 22 inch radiator. I sold it to a memebr of my car club to put in his dart.
I had intended to just buy a "stock" 26 inch radiator, but didn't realise the mounting probelms I would have until recently. (yeah, it's my first mopar, first old car period!)
The thing is, everyone I call wants to sell me a racing aluminum radiator, usually for almost $500.00. When I ask, "and your sure it will fit", they reply with, "well there's always some fabrication...".
I don't want any fabrication, and am hoping a copper core will be cheaper than an aluminum.
[Re: uh60lbhawk]
#131496
10/03/08 05:22 AM
10/03/08 05:22 AM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
I bought a stock style 4 core non-aluminum radiator that bolted right in.
[Re: BADBEE]
#131499
10/03/08 02:18 PM
10/03/08 02:18 PM
DaytonaTurbo
Manitoba, Canada
I put in an aluminum 22" AFCO rad and it cools great, even without a shroud. Was not a stock bolt-in, I did have to drill holes for it, but I got it off ebay for about a hundred bucks brand new. Even sitting in traffic on a hot day it doesn't heat, so for now I see no reason to add a shroud. I run a 4 blade fixed fan. I'm sure someone makes a good stock style 22" rad, but will be more pricey than a universal aluminum.
[Re: stubbs300 ]
#131501
10/03/08 08:57 PM
10/03/08 08:57 PM
uh60lbhawk
Salem, OR USA
Let be honest, shall we? You say your deploying after the new year. Your project will be put on hold while your gone, right? Why not just plan on and save your "Hostile fire" pay along with the tax free that you'll get for being in the AOR and either get a recore job or buy what you want with that $$$! Studying your PME so you can get promoted wouldn't hurt either.
Well, firstly, as I said, I want to drive the car before I leave.
Secondly, if you mean Area Of Responsibility, then yes, I'll get "Hostile fire". Unfortunately, my original "estimate" from the body shop was $10,000 to $12,000. I took $20,000 out of my civilian "thrift savings plan" as a loan to cover the body work, engine and transmission. As I stated, the body work total is over $20,000 now. I have $5,000 in the engine, and another $1,500 in the tranny. I had to take out another loan against my wife's car to cover it! Thus any "Hostile fire" pay (and any other extra pay) is already spoken for to pay back the loans.
I had to Google PME. From what I gather it's an Air Force officer thing. I am neither Air Force, nor an officer. I am however a full time D.O.D. civilian during the week. I'm just fine where I'm at, thanks.
Actually, I contacted USRadiator. They have what I am looking for, bolt in, copper, for $367.50. That's probably my best option, unless anyone has the same for less.
[Re: General 68]
#131502
10/03/08 09:01 PM
10/03/08 09:01 PM
uh60lbhawk
Salem, OR USA
I went the same route as BADBEE did. Drilled two holes in the passenger side radiator support and put like 3/8 shims between radiator and support on that side. Used stock holes on drivers side. Works great.
Did you use a shroud? If so, did it line up with the engine? I've heard that getting it to line up that way can be a pain.
[Re: uh60lbhawk]
#131504
10/03/08 09:17 PM
10/03/08 09:17 PM
Posts: 1,069 Washington State
70Duster440
Washington State
I've got the #35455 from US Radiator (22" for RB) in my Duster w/440. In summer weather I can't keep it in the 180-195 range like I'd like. I guess it depends on how you define "hot" coolant temps and what you're comfortable with. Tried a new clutch fan and repro shroud to no avail along with a high flow stat and water wetter. Pushes 210+. The repro Mopar shroud does not fit the radiator correctly. In fact, when it gets warm it droops into the fan! Ended up taking it off and trying a Derale electric fan. Results about the same. Now that the weather has cooled here it is better but I need a long-term solution so I'll be considering an aluminum unit. Food for thought.
[Re: uh60lbhawk]
#131505
10/03/08 09:23 PM
10/03/08 09:23 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I had mine re-cored at the local rad shop with a high density 3 row core (core came from Spectra IIRC) for less than $250 but that was 2 years ago. 493 in a C-body with a 4 blade fan and no shroud it never goes over 180 if you're moving but it will creep up at idle. It hasn't been an issue but a 7 blade clutch with a shroud is on the list.
Kevin
[Re: uh60lbhawk]
#131507
10/03/08 10:06 PM
10/03/08 10:06 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Thanks, Clint
I bought the aluminum 22" rad that mancini sells. It's a direct replacement and I bought the shroud to go with it. I used a solid drive 6 blade flexilite fan with a shroud. It sits in front of a 600HP Hemi. Hottest it got was 190 during a hot, humid day. I tried a clutch fan (you have to use the 96 Jaguar clutch as the Mancini rad is thicker than stock), but it would heat up idling and would have a hard time recovering.
[Re: torkrules]
#131508
10/03/08 10:37 PM
10/03/08 10:37 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
I bought an aluminum A body radiator from a guy in california last week for $209.00 The fit was really really close, but not close enough for my restoration. It may work out for you guys need to get rid of the heat more than my 340 need to. you can get a hold of him here if interested. Cid Martin cidmartin@cox.net
[Re: General 68]
#131510
10/03/08 11:07 PM
10/03/08 11:07 PM
Posts: 2,874 Upstate, NY
sixpack4spd
Upstate, NY
This is the correct answer. Drill 2 holes and bolt the 26" radiator in. You can even buy an aluminum e-bay bolt in radiator for about $200
