Has anybody ran those Hughes rocker arms
#1314996
10/04/12 02:33 PM
10/04/12 02:33 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
The US made ones they are selling on any smallblock standard head stuff that has some spring pressure? One minute i am thinking old school, the next minute Gen 3 hemi But as i am old, i think i have an idea what i want to do with my Demon http://www.hughesengines.com/Index/produ...mp;partid=27161
Re: Has anybody ran those Hughes rocker arms
[Re: moparacer]
#1315008
10/04/12 08:58 PM
10/04/12 08:58 PM
B3422W5
Portage,michigan
Thanks Rod Yeah I had read that a while back, regards the treating. I know these particular rockers are different than the I believe it was Probe stuff they used to carry or maybe still do. Just looking at what options are out there for roller cams on stock style heads that don't require clearancing and can hold up to probably 550-600 spring pressures The HS stuff doesn't impress me and requires being whittled on to run 1.55 springs from what I have heard.
[Re: B3422W5]
#1315009
10/04/12 09:07 PM
10/04/12 09:07 PM
Posts: 25 California
Mad Dart
California
Yes I have ran them. 410 SB, 4spd. Revved it up all day to 7200RPM. They work well. This was with as Solid Flat Tappet though, 262@50 w/.624 Lift. They held the valve adjustment very well, hardly ever needed to adjust them and if so only a few exhaust valves. Was using Manton Ball Cup push Rods, oil thru on LA Heads. Pressureized oil on the ball and cup. Was also running Johnson Oil through EMD Lifters. FWIW
[Re: moparacer]
#1315010
10/04/12 09:09 PM
10/04/12 09:09 PM
After talking(or should I say, TRYING to talk) to 'em on the phone...
NEVER AGAIN...
Went with Harland's and ain't looking back...
You too? I just called them earlier in the week and I was a little put off by the attitude to say the least.
Really!? I have NEVER heard that before...
Hughes and Indy. Where customer service is #1,356. Right on the priority list after cleaning the toilets.
[Re: Dunnuck Racing]
#1315013
10/04/12 10:55 PM
10/04/12 10:55 PM
B3422W5
Portage,michigan
Do Jesel or T&D make standard head rocker gear
