Auxiliary Trans Cooler: Bypass Radiator Cooler? #1314393
10/02/12 08:17 PM
10/02/12 08:17 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I've got a B&M Supercooler on my car. Right now it is routed to the radiator trans cooler first then the B&M auxiliary cooler.
What are most people doing with their street/strip cars? Running through both the radiator trans cooler and auxiliary trans cooler or bypassing the radiator trans cooler and just running in and out of the auxiliary trans cooler?
The car is in a warm climate here in SoCal and I'm running a Dynamic 9.5 converter and a deep pan. Thanks for any feedback.
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: 67Satty] #1314394
10/02/12 08:30 PM
10/02/12 08:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I always bypass the radiator.
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: justinp61] #1314395
10/02/12 08:41 PM
10/02/12 08:41 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
x2.
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: rickraw] #1314396
10/02/12 09:40 PM
10/02/12 09:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
x2.
Agreed.............why add more heat.........
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: Thumperdart] #1314397
10/02/12 10:34 PM
10/02/12 10:34 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I don't agree. Conventional wisdom is to pass through the radiator first, then on to the dedicated cooler. The radiator, while not as effective as a good dedicated cooler, is going to offer some cooling effect. The trans fluid on the out side of the tranny is likely in the 180 - 200 range; the coolant in the cool side of the radiator is most likely quite a bit cooler than that. Might as well run it through there to at least start the cooling process. It certainly cant hurt, and will only make the dedicated cooler that much more effective.
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: 67Satty] #1314398
10/03/12 03:08 AM
10/03/12 03:08 AM
Put a trans. temperature gauge in it and see what it runs, Dominick, Thumperdart, did and found out that his trans was running way cooler than it should have been run ATF needs to be ran at or above 160 F in a street car for the additives to work properly Yoou may need to run the fluid through the radiator to get it to run at those temps, maybe not
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: StealthWedge67] #1314399
10/03/12 05:42 AM
10/03/12 05:42 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Auxiliary Trans Cooler: Bypass Radiator Cooler? [Re: 67Satty] #1314400
10/03/12 02:21 PM
10/03/12 02:21 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
leave it alone you have it installed correctly
