400 main bearings? #1314204
10/02/12 04:35 AM
10/02/12 04:35 AM
ca
brownout Offline OP
brownout  Offline OP
ca
The plan is to build a 500" based on a 400 block. Aluminum rods, and main caps with block filler. Looking to make about 700 hp on motor and have a 300 hit or so of nitrous. I have an eagle crank with the standard 400 mains. I am finding that the main bearing selection is very limited. I see 440 source carries chamfered clevite p-series bearings full groove. I am wondering if these will be able to handle what I have planned. Are there any other options that anybody knows of?? Any information or experience is appreciated.
Thanks, Cody
Re: 400 main bearings? [Re: brownout] #1314205
10/02/12 05:19 AM
10/02/12 05:19 AM
Arizona
Chris'sBarracuda Offline
Arizona
King bearings..
Check with Dan (Performance Only) or Todd (Competition Wedge)..
Sealed Power: Z4094M
King: MB555AM010..-- That's a .010 number.
Chris..
Re: 400 main bearings? [Re: Chris'sBarracuda] #1314206
10/02/12 09:56 AM
10/02/12 09:56 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
i will second king bearings and also add that you should be running a girdle on the mains or be watching very closesly for cap walk.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 400 main bearings? [Re: brownout] #1314207
10/02/12 09:58 AM
10/02/12 09:58 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
If your crank has the right chamfer you do not need a chamfered main bearing. I have an eagle crank that was cut down to low deck main size and bearings fit it right out he of the box.
Welcome to the world of the red headed step child of mopar big blocks , main bearing selection for low decks suck .
Re: 400 main bearings? [Re: Jerry] #1314208
10/02/12 10:05 AM
10/02/12 10:05 AM
ill
dennismopar73 Offline
ill
Seen cap walk on mild 440 build,
But I do agree , a Girdle, and 'crete' the block1
Re: 400 main bearings? [Re: brownout] #1314209
10/02/12 03:05 PM
10/02/12 03:05 PM
ca
brownout Offline OP
brownout  Offline OP
ca
thanks for the responses every one I will look into the king bearings.
I didnt see any in standard size just .01 under and so on.
Cody
Re: 400 main bearings? [Re: brownout] #1314210
10/02/12 10:39 PM
10/02/12 10:39 PM
NC
440Jim Offline
440Jim  Offline
NC
Sorry, I can't help with that.
When I put aluminum main caps on my 400 blocks, I had them machined to 440 main bearing size. Precisely for the better bearing selection. Also, in case I ever go to an aftermarket block, my Callies crank with 440 mains will swap right over to the better block.
Re: 400 main bearings? [Re: Chris'sBarracuda] #1314211
10/02/12 10:49 PM
10/02/12 10:49 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
King bearings..
Todd may have them or something in stock that will you. Send him a PM
Michael
Re: 400 main bearings? [Re: SILVER67] #1314212
10/03/12 12:53 AM
10/03/12 12:53 AM
ca
brownout Offline OP
brownout  Offline OP
ca
440jim I see where that would have been a smart move.
I emailed todd I hope to hear back from him soon.
Once again thanks for the help everyone.
