Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets #1313889
10/01/12 07:04 PM
10/01/12 07:04 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Just a quick FYI for anyone looking for something w/ the same basic thickness & combustion chamber diameter & volume as the standard Fel-Pro 8519 PT-1 PermaTorque head gasket, only a bit more heavy duty for higher compression applications. I've finally had a chance to do a side-by-side comparison of the 8519 PT-1 w/ the 17059 "Marine" series head gasket and from what I can tell they are dimensionally identical.
And if the Fel-Pro tech info I've been able to find on their various head gasket types apply to the bb Mopar gaskets as described as for bb Chevy gaskets, the 17059 is constructed the same as their Performance-series gaskets w/ the exception of not having the steel wire in the fire ring. That's fine with me because I don't like how the pre-flattened wire rings still brinell aluminum heads.
What I don't know for sure is what the volume of the 8519 PT-1 or 17059 end up being when compressed. The spec I see for the 17059 says 10.3 cc IIRC, but what I found a long time ago (but can't locate now) for the 8519 PT-1 was more like 10.9 cc. Also, these things must crush quite a bit when torqued down because they're listed as having compressed thicknesses of ~ .040", but two quick measurements I took of them right out of their packages came up more like .048".
Either way, they both have a large enough ID to clear my 4.380" bores w/o excessive gap being left, plus the scallops where they're opened up a bit more for room for the valves just clear the CNC'd chambers of my Victor heads w/o any overhang into the bore.
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: BradH] #1313890
10/01/12 08:00 PM
10/01/12 08:00 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Good info..I am about to buy a set of gaskets myself.
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: BradH] #1313891
10/01/12 09:04 PM
10/01/12 09:04 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
The Fel Pro " official" specs for the 8519 are 4.505 bore ( careful where you measure), .039 cc compressed, and 11.2 cc volume....carry on...
RIP Monte Smith
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: CompWedgeEngines] #1313892
10/01/12 11:45 PM
10/01/12 11:45 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Where do the 1009's fall in the mix?
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: Jeremiah] #1313893
10/02/12 12:17 AM
10/02/12 12:17 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: BradH] #1313894
10/02/12 08:13 AM
10/02/12 08:13 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run the Marines on my 440.It has 12.5 domes and the first Stealth heads.They as said list at .039 compressed thickness.Mine have been on 4 years street/strip.No problems.Rocky
Chrysler Firepower
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: pittsburghracer] #1313895
10/02/12 11:11 AM
10/02/12 11:11 AM
BradH Offline OP
BradH  Offline OP
Or, in summary, the 1009s have...
- smaller bore diameters that are hit-or-miss on 4.375" bores depending upon the size of the chamfer at the top of the bores, and may hang into the combustion chambers where they flare out at the valves and...
- the steel wires in the fire rings that brinell ("leaves dents") in aluminum heads.
I've used the 1009s w/ good results on 4.375" "no chamfer" blocks and OEM iron heads, but won't use them w/ aluminum heads now.
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: CompWedgeEngines] #1313896
10/02/12 11:19 AM
10/02/12 11:19 AM
BradH Offline OP
BradH  Offline OP
I'd say based on what I've seen that both the 8519 PT-1 & 17059 are the same volume, regardless of whether Fel-Pro claims almost a full cc difference or not.
What they actually measure when compressed (10.3, 11.2, ???), I can't actually say at this time.
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: BradH] #1313897
10/02/12 11:31 AM
10/02/12 11:31 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
From past research my notes indicate the exposed fire ring in the PT was a tin material, and it was stainless steel in the 059 marine.
And because of that I always believed the stainless steel, being harder than tin, would probably do more damage to an aluminum head, and that's why I never used it.
Please correct me if I am wrong on that?
Thanks!
Rich H.
Esse Quam Videri
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: ZIPPY] #1313898
10/02/12 05:31 PM
10/02/12 05:31 PM
BradH Offline OP
BradH  Offline OP
Thanks!
I think it's the wire o-ring, rather than the stainless steel "wrapper", that's leaving the indentations... I believe the DG gaskets I used to run also had stainless fire rings w/o any wire insert and they never left a mark on my Stage VIs after multiple uses.
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: BradH] #1313899
10/02/12 08:16 PM
10/02/12 08:16 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
dont know about a bb but I tried there marine gaskets on my 14-1 sb and they did not hold up at all.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: BradH] #1313900
10/03/12 01:34 AM
10/03/12 01:34 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Brad these are a WAG but i tend to agree with you're thinking. i do often question the volume specs especially if the gasket appears to have identical dimensions. i don't feel like digging out the felpro catalog right now but am pretty sure the marine gasket has a stainless fire ring and tend to agree (though no direct experience) it's the encased wire on gaskets that impacts the head. i popped a 8519 on my engine and replaced it in kind but always questioned that choice. if i keep the car and end up pulling the engine down i was thinking about using the marine gasket or MLS
Re: Fel-Pro 8519 PT-1 vs. 17059 "Marine" BB head gaskets [Re: dusturbd340W5] #1313901
10/04/12 01:01 PM
10/04/12 01:01 PM
BradH Offline OP
BradH  Offline OP
Not surprised; with that much CR and small-blocks having fewer head bolts, I'd expect that would require MLS stuff to survive.
