pt cruiser burnt valve #1312424
09/29/12 01:10 PM
09/29/12 01:10 PM
md
mopars4ever Offline OP
md
What would cause a burnt exhaust valve on #4 cylinder on 07 PT cruiser with only 57,000 miles?
Re: pt cruiser burnt valve [Re: mopars4ever] #1312425
09/29/12 01:42 PM
09/29/12 01:42 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Piss poor factory valve job. Not that uncommon on the 2.0 and 2.4 engines. Ive seen a bunch, especially on the 2.0 neon engines.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: pt cruiser burnt valve [Re: mopars4ever] #1312426
09/29/12 04:26 PM
09/29/12 04:26 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Is that a confirmed diagnosis? We have done a ton of Mopars with 2.0 and 2.4 engines. I can't remember the last burnt ex valve I have seen. I'm not saying it doesn't happen, I just haven't run into it.
I'ld certainly make sure that was the problem BEFORE tearing into it.
Master, again and still
Re: pt cruiser burnt valve [Re: DaveRS23] #1312427
09/29/12 05:32 PM
09/29/12 05:32 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
It could have been overheated. I know of one like that, has a slight roughness @ idle. One of the exhaust valves/seats is bleeding off some pressure.
Re: pt cruiser burnt valve [Re: topside] #1312428
09/29/12 07:58 PM
09/29/12 07:58 PM
Missouri U.S.A.
Missouri U.S.A.
When I worked at the dealer it was common on the later, say 04 and up engines. If they were not totally burned and zero compression, one hole would be down at least 40 or more psi causing the engine to trip the misfire monitor.
10.02@134
Re: pt cruiser burnt valve [Re: 71yelladustr] #1312429
09/29/12 08:38 PM
09/29/12 08:38 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
Sorry to say but it is fairly common for those and the 2.0 to burn the exhaust valves.
Re: pt cruiser burnt valve [Re: mod381] #1312430
09/29/12 09:27 PM
09/29/12 09:27 PM
md
md
It had number 4 misfire and low compression on that cylinder. Never overheated. Car ran rough for a while. Car is apart and the head is at the machine shop. I did some online searches and it appears to quite common even on low mileage PT`s. Just looking for ways to try and prevent it from happening again. By the way, we had a 03 Neon with a 2.0 with 168,000 on it and it never had any internal engine problems.
