Re: pt cruiser burnt valve
[Re: mopars4ever]
#1312425
09/29/12 01:42 PM
09/29/12 01:42 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Piss poor factory valve job. Not that uncommon on the 2.0 and 2.4 engines. Ive seen a bunch, especially on the 2.0 neon engines.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: mopars4ever]
#1312426
09/29/12 04:26 PM
09/29/12 04:26 PM
Posts: 12,097 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Is that a confirmed diagnosis? We have done a ton of Mopars with 2.0 and 2.4 engines. I can't remember the last burnt ex valve I have seen. I'm not saying it doesn't happen, I just haven't run into it.
I'ld certainly make sure that was the problem BEFORE tearing into it.
Master, again and still
[Re: topside]
#1312428
09/29/12 07:58 PM
09/29/12 07:58 PM
71yelladustr
Missouri U.S.A.
When I worked at the dealer it was common on the later, say 04 and up engines. If they were not totally burned and zero compression, one hole would be down at least 40 or more psi causing the engine to trip the misfire monitor.
