Edelbrock CNC porting, do I Need?
#1311481
09/27/12 12:58 PM
09/27/12 12:58 PM
Posts: 192 central Florida
titan
central Florida
Hi, Am Building A 451 Low Deck Stroker, & am At The Stage Of Adding The Heads. Initial Plans Were To Have My O.O.T.B Edelbrock Heads CNC Ported,But Wondering If It Would Be Worth The Cost Right Now Concidering I Am Only Using The MP 528 Solid Cam & Is Strictly A Street Machine Not Seeing More Than 6000rpm.
Re: Edelbrock CNC porting, do I Need?
[Re: titan]
#1311484
09/27/12 05:27 PM
09/27/12 05:27 PM
Posts: 2,177 ill
dennismopar73
ill
Hi, Am Building A 451 Low Deck Stroker, & am At The Stage Of Adding The Heads. Initial Plans Were To Have My O.O.T.B Edelbrock Heads CNC Ported,But Wondering If It Would Be Worth The Cost Right Now Concidering I Am Only Using The MP 527 Solid Cam & Is Strictly A Street Machine Not Seeing More Than 6000rpm.
We had a 451 with o o b eddy rpms, ran 9.80 132mph, 3200# duster! should be easy low 10s
[Re: dennismopar73]
#1311486
09/27/12 09:33 PM
09/27/12 09:33 PM
Posts: 2,449 nc
earthmover
nc
lets hear more about this 451..lol if you dont mind.. as i have a 451 in going in my duster
[Re: gch]
#1311489
09/27/12 10:55 PM
09/27/12 10:55 PM
Posts: 2,177 ill
dennismopar73
ill
(quote)lets hear more about this 451..lol if you dont mind.. as i have a 451 in going in my duster (quote) 400 block, old set arias pistons, comp 12-1? 5500 stall TA vert 430 gears dana, racer brown stx 21 cam (solid),intstalled 102 c/l (106Adv) stock eddie rpms, 980 carb, then changed dual quad 650 set up, stock rebuilt 727
[Re: dennismopar73]
#1311494
09/28/12 01:07 PM
09/28/12 01:07 PM
Posts: 2,449 nc
earthmover
nc
maybe my car will run ok.. 451 400 block je dome tops on eagle h beams eagle crank hard filled to water pump hole rbre billet main 440-1 heads with 2.25 valve other then that out the box t&d 1.5 rockers cam motion roller 715 lift after lash indy 400 intake with 4500 top 727 trans with either 8" turbo action 5600 or 9.5 dynamic 5000 73 duster chassis car with 9" rear 4.30 gear should be around 2400/2500 ready..
