Re: Broke the Car ,,,pics included
[Re: racerhog]
#1310672
03/06/13 07:31 PM
03/06/13 07:31 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Update;
1) Converter was sent out to Turbo Action, and they went thru it. They had to repair/replace a few of the "feet" or pads that the converter bolts thread into. They also said the ring gear and snout needed some attention. Converter is back and ready to go
2) Trans is out, and at CRT getting a once over to make sure everything is ok.
3) bought a new starter, B & M flex plate, and ARP convertor bolts
4) still have to pull and change the cam plug on the back of the motor ( when the weather breaks ).
5) Once the trans is back, i should have it back together in a few hours.
Thanks for everyone's posts. ( i forgot i posted this last year, Ramcharger found my old post, lol )
[Re: pittsburghracer]
#1310674
03/06/13 07:44 PM
03/06/13 07:44 PM
69CHARGERMD
KENTUCKY
looking back, I probably didnt do a good job "cleaning" the convertor bolts before installing them. They were not dirty, but I suspect they could of had some oil, debris, etc on them. Lots of carnage for a inexpensive bolt,,, Thanks guys ! ( thanks pittsburg )
[Re: 69CHARGERMD]
#1310677
03/06/13 11:21 PM
03/06/13 11:21 PM
Posts: 1,118 Central Missouri - USA
Ramcharger
super gas
super gas
Update;
Yeah, I've been away from moparts for a while. I looked back at your posts to see how fast the Belvedere was these days. That's when I discovered the post about the breakage.
Glad to hear the repairs are progressing. Any online videos or pics of the Belvedere racing lately?
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop) '99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54 '89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift '14 Dodge Dart Limited 2.4/6-speed A/T
[Re: Ramcharger]
#1310678
03/07/13 12:41 AM
03/07/13 12:41 AM
69CHARGERMD
KENTUCKY
I'll try and post some. Ran a 10.04 at Norwalk last year, 1.38 60' ( best et so far ) Normally runs in the 10 teen range with a 1.40 to 1.43 60'
[Re: 69CHARGERMD]
#1310679
03/07/13 10:09 PM
03/07/13 10:09 PM
Posts: 553 Kentucky
clovis
Kentucky
Get that thing together and come test and tune with us on Saturday at Beech Bend.
I just added check converter bolts to my to do list for Friday night.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
[Re: clovis]
#1310680
04/05/13 08:01 PM
04/05/13 08:01 PM
69CHARGERMD
KENTUCKY
update; 4/5/2013 Have all parts back. 1) trans is all fresh and ready to go, Thank you John ( CRT ) 2) convertor re-done, fixed, and ready to go 3) new flex plate, starter, ARP bolts
Got the flex plate on, and will get the trans in shortly, should go quick after that. I did replace the rear cam plug with the motor in the car, what a pain in the #$%$#%#,
