Page 3 of 3 1 2 3
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310671
03/05/13 12:03 PM
03/05/13 12:03 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
So when you here that ticking noise that you havent found...... Check convertor bolts now!
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Broke the Car ,,,pics included [Re: racerhog] #1310672
03/06/13 07:31 PM
03/06/13 07:31 PM
KENTUCKY
69CHARGERMD Offline OP
KENTUCKY
Update;
1) Converter was sent out to Turbo Action, and they went thru it. They had to repair/replace a few of the "feet" or pads that the converter bolts thread into. They also said the ring gear and snout needed some attention. Converter is back and ready to go
2) Trans is out, and at CRT getting a once over to make sure everything is ok.
3) bought a new starter, B & M flex plate, and ARP convertor bolts
4) still have to pull and change the cam plug on the back of the motor ( when the weather breaks ).
5) Once the trans is back, i should have it back together in a few hours.
Thanks for everyone's posts. ( i forgot i posted this last year, Ramcharger found my old post, lol )
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310673
03/06/13 07:39 PM
03/06/13 07:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Don't forget to clean the new bolts in (lacquer thinner) as most have some form of lubrication to keep from rusting. Buy a small fresh tube of 271 (red) loc-tite. Tighten the **** out of them. And go have fun. Good-luck this year and I hope all goes well.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Broke the Car ,,,pics included [Re: pittsburghracer] #1310674
03/06/13 07:44 PM
03/06/13 07:44 PM
KENTUCKY
KENTUCKY
looking back, I probably didnt do a good job "cleaning" the convertor bolts before installing them.
They were not dirty, but I suspect they could of had some oil, debris, etc on them.
Lots of carnage for a inexpensive bolt,,,
Thanks guys ! ( thanks pittsburg )
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310675
03/06/13 08:34 PM
03/06/13 08:34 PM
tboomer Offline
tboomer  Offline
Good luck,Doc!
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310676
03/06/13 08:43 PM
03/06/13 08:43 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
good luck this year on the car Doug. also did you ever get to do to your truck that we talked about?i just put EFI on mine and am loving it.thanks Bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310677
03/06/13 11:21 PM
03/06/13 11:21 PM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
Update;
Yeah, I've been away from moparts for a while. I looked back at your posts to see how fast the Belvedere was these days. That's when I discovered the post about the breakage.
Glad to hear the repairs are progressing. Any online videos or pics of the Belvedere racing lately?
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: Broke the Car ,,,pics included [Re: Ramcharger] #1310678
03/07/13 12:41 AM
03/07/13 12:41 AM
KENTUCKY
KENTUCKY
I'll try and post some.
Ran a 10.04 at Norwalk last year, 1.38 60' ( best et so far )
Normally runs in the 10 teen range with a 1.40 to 1.43 60'
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310679
03/07/13 10:09 PM
03/07/13 10:09 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
Get that thing together and come test and tune with us on Saturday at Beech Bend.
I just added check converter bolts to my to do list for Friday night.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Broke the Car ,,,pics included [Re: clovis] #1310680
04/05/13 08:01 PM
04/05/13 08:01 PM
KENTUCKY
KENTUCKY
update; 4/5/2013
Have all parts back.
1) trans is all fresh and ready to go, Thank you John ( CRT )
2) convertor re-done, fixed, and ready to go
3) new flex plate, starter, ARP bolts
Got the flex plate on, and will get the trans in shortly, should go quick after that.
I did replace the rear cam plug with the motor in the car, what a pain in the #$%$#%#,
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310681
04/05/13 08:06 PM
04/05/13 08:06 PM
tboomer Offline
tboomer  Offline
Good luck,Doc!
Re: Broke the Car ,,,pics included [Re: 69CHARGERMD] #1310682
04/06/13 08:46 AM
04/06/13 08:46 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Don't forget to clean the oil out of the convertor bolt holes!
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Page 3 of 3 1 2 3
