Removing paint from rubber weatherstrip? #1310381
09/25/12 12:18 PM
09/25/12 12:18 PM
Texas
carcrazyguy Offline OP
Texas
Starting to get the Dart clean up. It was painted in 2005 and has not been really cleaned since (stored inside). There is some paint/overspray on the weatherstrip on the tops of the doors (just below the vent window). What can I use to get the paint off?
Re: Removing paint from rubber weatherstrip? [Re: carcrazyguy] #1310382
09/25/12 12:21 PM
09/25/12 12:21 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Right after paint I'd use lacquer thinner, 7 years later... good luck.
Re: Removing paint from rubber weatherstrip? [Re: Challenger 1] #1310383
09/25/12 12:32 PM
09/25/12 12:32 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'd start with 000 steel wool or a scotch brite pad. should be just abrasive enough to get the paint off without chewing up the rubber too much
**Photobucket sucks**
Re: Removing paint from rubber weatherstrip? [Re: carcrazyguy] #1310384
09/25/12 01:39 PM
09/25/12 01:39 PM
New York
EF8aar Offline
EF8aar  Offline
New York
if it's just light overspray try "Goof Off"
http://www.goofoffstainremover.com/
Re: Removing paint from rubber weatherstrip? [Re: 70Cuda383] #1310385
09/25/12 01:43 PM
09/25/12 01:43 PM
nj
MoJoe Offline
MoJoe  Offline
nj
Had similar situation and after trying laquer thinner and acetone with marginal results, I went with the steel wool and white vinegar...worked great
Re: Removing paint from rubber weatherstrip? [Re: carcrazyguy] #1310386
09/26/12 01:13 AM
09/26/12 01:13 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
This technique is more for a convex shaped rubber part: Point a razor blade straight on the rubber part, then scrape rapidly back and forth. It's like scraping food off a plate with a knife: cleans the food off but doesn't hurt the plate.
If you are really patient and take your time you won't shave off any of the rubber.
Steel wool will leave the rubber with a dull, worn out appearance. DAMHIK
Concave rubber is alot trickier......
Mo' Farts
Moderated by "tbagger".
