Re: Superbird Headlight Door Vaccum Switch
[Re: sixpackbird]
#1309371
09/23/12 05:51 PM
09/23/12 05:51 PM
Posts: 3,519 Lansing, MI
70gtx440dana
Lansing, MI
I have an original vacuum switch. This is the white plastic one that attaches to the headlight switch. PM me if you are interested. Joe
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
[Re: convx4]
#1309376
09/26/12 09:54 AM
09/26/12 09:54 AM
Posts: 6,583 SE Pa.
LimeliteAero
SE Pa.
Handmade with metal inserts.
[Re: sixpackbird]
#1309378
09/26/12 03:01 PM
09/26/12 03:01 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The nubs are fine, it will not hold vacuum, the seal is apparently worn out.
They use a light coat of grease on the slider,it dries with age and won't seal.If you are careful you can take the switch apart,clean it and use a good quality grease.You can take it apart and put it back together with a little common sense,did mine years ago and it still works.Also,there are a lot of sources for leaks on that system,hoses,check valve in reserve can and headlight actuators.Get a hand vacuum pump and eliminate them one at a time.
