Re: Anyone Know Pushbutton Trannies?
[Re: Hey19]
#1309167
09/23/12 01:51 AM
09/23/12 01:51 AM
Posts: 43,287 Bend,OR USA
Cab_Burge
I use the method that I adjust the cable so the pin on the cable will drop in with out pushing hard into the lever from the valve body in nuetral, 1st, 2nd and 3rd gear, it won't come out of the valve body lever all the way in reverse due to cable length. One bolt hole will make the difference between perfect and not perfect. Don't worry to much about the drive shaft turning in nuetral, not uncommon, especially on a fresh rebuld. Get it adjusted properly and go have fun
[Re: 64Post]
#1309170
09/23/12 10:16 AM
09/23/12 10:16 AM
Posts: 3,916 usa
lewtot184
usa
If John Kunkel doesn't respond to your thread in a day or so send him a PM.
x2, john's the man for this.
[Re: Hey19]
#1309171
09/23/12 04:36 PM
09/23/12 04:36 PM
Posts: 25,966 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Never test the functioning of an automatic trans while the car is on jackstands, the "windmilling" action of the released clutches will make the wheels turn....even in Neutral.
[Re: Hey19]
#1309174
09/24/12 06:03 PM
09/24/12 06:03 PM
John_Kunkel
Rio Linda, CA
The absolute best way to adjust the cable is to pull the pan and use a small inspection mirror to observe the position of the detent ball in each position.
Barring that, adjusting the cable so that the NSS contact is in the center of the hole in Neutral usually works OK. The factory recommended procedure has always worked for me.
