My '67 GTX has a spring which goes over the nut which holds the steering wheel onto the column,
then You install the center cap by depressing the spring and turning the center cap clockwise to lock..Then You can press on the outer trim ring to
make the horns blow,right?? because the spring is supposed to touch the internal ring which grounds
the circuit,right???Well,depending on how I position the spring before installing the center
cap, I can get the horns to blow constantly, or not at all !!! I have asked several Mopar Friends,
and pored thru several manuals,but can't find one damn sentence or picture which provides any guidance.. Can someone help???
