Horns either blow continuously or not at all-- HELP !!! #1308709
09/22/12 10:59 AM
09/22/12 10:59 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
My '67 GTX has a spring which goes over the nut which holds the steering wheel onto the column,
then You install the center cap by depressing the spring and turning the center cap clockwise to lock..Then You can press on the outer trim ring to
make the horns blow,right?? because the spring is supposed to touch the internal ring which grounds
the circuit,right???Well,depending on how I position the spring before installing the center
cap, I can get the horns to blow constantly, or not at all !!! I have asked several Mopar Friends,
and pored thru several manuals,but can't find one damn sentence or picture which provides any guidance.. Can someone help???
Re: Horns either blow continuously or not at all-- HELP !!! [Re: gassy66] #1308710
09/22/12 03:04 PM
09/22/12 03:04 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hm.is there a black cable attatched to the spring ,or horn pad?.on my -70 cuda the horn contact ring had loosen its insulation.its further down in the collumn,above the blinker switch??
Re: Horns either blow continuously or not at all-- HELP !!! [Re: cuda-sweden] #1308711
09/22/12 03:28 PM
09/22/12 03:28 PM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
No, nothing attached to spring,and ther wasn't anything else under/around the center cap..
Re: Horns either blow continuously or not at all-- HELP !!! [Re: gassy66] #1308712
09/22/12 11:27 PM
09/22/12 11:27 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
don't know much about that cap..but it seems like the cap should have a gap/space inside for the contacts to touch when pressed on..its possible the contacts are touching..making the horns go off..and also not working at times...is the cap new?..can you open it up and see?
Re: Horns either blow continuously or not at all-- HELP !!! [Re: AARCONV] #1308713
09/23/12 10:11 AM
09/23/12 10:11 AM
Canfield,Ohio,USA
gassy66 Offline OP
gassy66  Offline OP
Canfield,Ohio,USA
Nothing wrong with the center cap,and there were no other parts under that cap except the spring..
I know,'cuz I'm the one who disassembled everything and put stuff into bags with notes..
Maybe someone with a '67 Plymouth could remove thier center cap and send a pic of what's there??
