Re: Antenna Location
[Re: Eric_70_Chally]
#130817
10/01/08 10:57 PM
10/01/08 10:57 PM
Posts: 29,657 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
What is the radio code on your fender tag or broadcast sheet? What is the hood code? What is the scheduled production date? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ebodyseast]
#130819
10/01/08 11:46 PM
10/01/08 11:46 PM
Posts: 4,165 Florida
cataclysm80
IIRC - when the period that shaker hoods were on back order for '70 Challengers, T/A fiberglass hoods were installed in their place, and the antenna was then mounted at the rear instead of on the fender...just like a T/A.
I think that's just a rumor, and not quite all entirely true. Even if it were, the antennae would be on the passenger quarter like a T/A, Not on the drivers quarter.
I have heard of this drivers quarter antennae on a couple cudas. I don't think it's factory. More than likely the car was ordered without a radio and then an aftermarket unit was installed. Stereo shops also had tools to cut antennae holes, not just factory workers.
Tav
#130821
10/02/08 04:07 PM
10/02/08 04:07 PM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
The most probable explanation is aftermarket, maybe even a CB antenna "Good Buddy". ![](/ubbthreads/images/graemlins/grin.gif) FWIW the 4 known '70 N94 non-T/A Challengers May built HEMI - no radio June built HEMI - no radio July built 340 - R35 ant. on RT fender July built 383 - R11 ant. on RT fender
#130823
10/02/08 06:23 PM
10/02/08 06:23 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
Just at a glance at this post, I might have missed it said already, but the rear antenna location on the 70 T/A's were on purpose, a lesson learned on the 69 1/2 road runners & Bees with fiberglass hoods which encountered a lot of radio signal interference that would normally be shielded from the steel hood. I have a pic of an original location of antenna on a 69 1/2 RR but I'm apparently too stupid to figure out how to make the pic small enough to go this site... Anyone needs the pic just drop me a line and i'll email it to you. As to your original question Why is there a hole in the drivers side? Well, it was, after all , the 70's - maybe the previous owner added it to hang the all too common for the time Racoon Tail so he could look in the rear view mirror and watch it a flappin in the wind. Not helpful? sorry. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
[Re: ebodyseast]
#130824
10/02/08 08:19 PM
10/02/08 08:19 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
This is a myth actually. The Shaker hoods were available again on the Challenger R/Ts before the T/A hoods were available. ![](/ubbthreads/images/graemlins/wink.gif)
Back to the original poster, it sounds like the hole was added at some point.
