67 Dodge Dart inside door arm rest and door handle HELP #1307980
09/20/12 11:21 PM
09/20/12 11:21 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hello, I am working on a 1967 Dodge Dart 2-door Hard top and I have the 10 point cage almost finished but I noticed something.....when I was sitting in the drivers seat and closed the door...I can't put the factory door arm rest base and pad on the door because it will hit the door brace.
So..I know I am not the only one that has had this problem...so can anyone tell me what they did for an arm rest base for the inside door handle???
I am open for Suggestions? I want the car to look real good...so I want something that I can buy or make to make it look good when the door panel is installed.
You can post here or send me an e-mail to; glr7069@ptd.net
Thank you!
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: GLR] #1307981
09/20/12 11:25 PM
09/20/12 11:25 PM
Renton Washington
Triple Threat Offline
Renton Washington
I just left them off. I too wish there was something to grab, usually just roll the window down and use the top of the door or the wing window handle.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: GLR] #1307982
09/20/12 11:33 PM
09/20/12 11:33 PM
Out West
408strokerdart Offline
Out West
My door bars kick in in that area to clear the armrest. The X brace meets in about the same area, but it is fully functional and doesn't crowd me in the car at all.
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Triple Threat] #1307983
09/20/12 11:46 PM
09/20/12 11:46 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Yea..Triple Threat ,,,,The only thing I have thought of is using the pull straps that came on the Dodge Conversion vans (I had one at one time) they would work to pull the door shut, but the area around the actual door handle ..especially in back of the handle won't look very good unless I can find some sort of short door bezel that will fit?
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Triple Threat] #1307984
09/21/12 01:10 AM
09/21/12 01:10 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Dustin is that a custom cage or a kit?
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: mshred] #1307985
09/21/12 02:00 AM
09/21/12 02:00 AM
Renton Washington
Renton Washington
Matt,
Kit from http://www.artmorrison.com/homepage2.php
Moly
I have thought about the strap, but i think they look cheesy. The bezel is the hard part.
-Dustin
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Triple Threat] #1307986
09/21/12 03:44 AM
09/21/12 03:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also left them off on my 63 and I want my interior to look as stock as I can keep it. I have thought about a strap but have not done it yet. I usually grab the vent window frame when closing the door when I am in the car. Ron
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: 383man] #1307987
09/21/12 04:52 AM
09/21/12 04:52 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
My door bars bend in to accommodate them. Its hard to tell in my pic though. If you really had to take them to an upholstery guy who can cut the area out for you to clear the bars.
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Twin Turbo Mower] #1307988
09/21/12 06:30 AM
09/21/12 06:30 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't have a picture. Using a grinder I cut an angled notch in the arm rest. Then using sandpaper wrapped around a piece of scrap roll bar tube I sanded it to the correct shape of the bar. The armrest was then covered with Vinyl. Now the armrest is notched around the bar.
Doug
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Triple Threat] #1307989
09/21/12 08:06 AM
09/21/12 08:06 AM
Toronto
mshred Offline
mshred  Offline
Toronto
Matt,
Moly
Thanks Dustin
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: dvw] #1307990
09/21/12 10:12 AM
09/21/12 10:12 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
DVW....Well, I thought of taking a 68-70 B-body arm rest base and cutting the center out of it and gluing it back together..but not sure yet. You have a good Idea that worked too. I was hoping that someone would have a real good idea and attach or send pictures of a nice looking door base...
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: GLR] #1307991
09/21/12 10:52 AM
09/21/12 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I assume the bars are already welded in... if so...
cut them out and have bars made with a bend in them
to go under the arm rest.. I'll get some pics today
hold I did mine on the Rampage
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: MR_P_BODY] #1307992
09/21/12 11:58 AM
09/21/12 11:58 AM
New Jersey
Craig Offline
Craig  Offline
New Jersey
Here in the NE division the bars have to be straight or it will not certify, I saw a beautifully crafted cage by a pro fail for that reason, door bar was bent for clearance. Sounds like your bar is already in though, I would modify the arm rest as others have described. I was lucky in that mine fit just beneath the armrest, 1-5/8 MS bars in an X, tied to a rocker sill bar (see pic).
67 Dart, 426 Hemi, 9.23/145mph, 3400lbs, footbraked, owned since 1982
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Craig] #1307993
09/21/12 12:12 PM
09/21/12 12:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you run a brace bar from the bend to the base of
the main hoop it will pass.... I have seen a bent
door bar pass also
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: MR_P_BODY] #1307994
09/21/12 12:40 PM
09/21/12 12:40 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I got a few old B body door arm rest bases and I have already cut one up to make one that will fit. I am not sure if I want to try and cut an old pad and use the factory hole in the base or not yet. It's either that or I come up with some sort of thing to pull the door closed...I thought I might go to Lowe's and get some ideas ??? and maybe go to a junk yard and start looking at some of the cars??
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: MR_P_BODY] #1307995
09/21/12 03:43 PM
09/21/12 03:43 PM
Mt.Vernon IL
Mt.Vernon IL
I got my cage certified last month and he never said anything about the door bar being bent, but it only has a slight bend just enough to clear. He was only concerned about the door bar being spring loaded for the swingout portion, his boss said it was ok he seen them before.
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: GLR] #1307996
09/21/12 06:05 PM
09/21/12 06:05 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I took an old 5 point harness crotch strap, removed the hardware from it and attached it to the driver door using that big screw (with a big washer) on the top metal surface. Make it long so you can reach it when strapped in...
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: actionange] #1307997
09/21/12 06:17 PM
09/21/12 06:17 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Mine go behind it.
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Bigcube] #1307998
09/21/12 11:06 PM
09/21/12 11:06 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
My arm rests squash the roll-bar padding, but bearly touch the bar itself. Don't know if you can see it in this picture or not.
Re: 67 Dodge Dart inside door arm rest and door handle HELP [Re: Craig] #1307999
09/21/12 11:19 PM
09/21/12 11:19 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
My door bars are bent and my cage cert just fine. Took it to the NHRA office on street road and had it certed in there parking lot. I have a x brace in my car that run right under my arm rests.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
