Why the epidemic of failed new cams? #1307322
09/20/12 10:17 AM
09/20/12 10:17 AM
South-Central (Sebring), FL
Commando1 Offline OP
I don't know if it's because I'm getting older and the stories are just accumulating or if there really has been an extreme epidemic of new cams getting wiped before the 2k mile mark.
I've heard all the stories.
Crap used in the Chinese forgings.
Companies becoming the Walmart of valve trains and skipping on QA/QC.
Oil formulation changes in the last few years for the worse.
Plus the eternal ever standard: "did ya break it in properly?".
It's happening in all the engines, from garage builds to pro builds.
I wish ASTM would do a comprehensive study on this but that ain't gonna happen.
The podium is now open....
Re: Why the epidemic of failed new cams? [Re: Commando1] #1307323
09/20/12 10:32 AM
09/20/12 10:32 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
I don't think it's as bad as at used to be say, a few years ago but you still hear about it.
I think the biggest reason was the new oil formulations that took the zinc and other things out of oil that flat tappet cams need. Most people in the hobby know about it by now, but it took a while for the average guy to realize that you can't just grab any old 10W-30 off the shelf to break in a cam anymore.
There was also word of a bad batch of mopar lifters floating around a few years back. Many people say Johnson made/make the best quality lifters but I think they were out of buisness for a while, so we probably had a lot of soft Chinese junk out there repackaged as many different brands.
Re: Why the epidemic of failed new cams? [Re: 440newport] #1307324
09/20/12 11:28 AM
09/20/12 11:28 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The story I heard it wasn't just Mopar, it was across the board. I don't know the name of the company but one of remaining 2 or 3 makers went belly up and the company that came in to sell off the remains saw loads of lifters that didn't pass inspection and SOLD them off as good. Its takenn a number of years for those lifters to make it thru the systems ...
Re: Why the epidemic of failed new cams? [Re: JohnRR] #1307325
09/20/12 12:20 PM
09/20/12 12:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The Dello diesel oil has the right amount of ZDDP in it for breaking in a cam, it should still be around 1500ppm, much less and you wipe out a cam lobe because it lacks the anti skuffing compound. Also most people are not checking for lifter rotation before starting, some of the lifters were slightly oversize and do not rotate in the bore, a small ball hone fixes that problem. Tim
Re: Why the epidemic of failed new cams? [Re: JohnRR] #1307326
09/20/12 02:41 PM
09/20/12 02:41 PM
Bain Capital?
J/K
Re: Why the epidemic of failed new cams? [Re: Commando1] #1307327
09/20/12 03:20 PM
09/20/12 03:20 PM
JohnRR Offline
JohnRR  Offline
Bain Capital?
J/K
Didn't Bain buy struggling companies and not companies that folded ?
Re: Why the epidemic of failed new cams? [Re: JohnRR] #1307328
09/20/12 03:42 PM
09/20/12 03:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
eaton quit making flat tappets, johnson went out of business and the only people left were stanadyne, the worst in the business. i also think that people wanting very agressive lobes, especially hydraulic flat tappet, to use in production blocks was a factor. the oil thing was probably the "cherry" on top the sundae.
Re: Why the epidemic of failed new cams? [Re: lewtot184] #1307329
09/20/12 05:08 PM
09/20/12 05:08 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
People using crap oils during break-in.
People not follow break-in procedures properly.
Modern cams have much more aggressive lobes than the lazy cams of yesteryear.
Re: Why the epidemic of failed new cams? [Re: Commando1] #1307330
09/20/12 05:11 PM
09/20/12 05:11 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I often wonder when I read about these failures if they are sometimes caused by improper setup. Wrong lash or preload.
It seems a lot of people screw that up and then blame everything but themselves?
Re: Why the epidemic of failed new cams? [Re: Commando1] #1307331
09/20/12 05:48 PM
09/20/12 05:48 PM
dogdays Offline
dogdays  Offline
Hasn't this issue been beaten TO DEATH?
BTW, cast iron cams are used for flat tappets.
R.
Re: Why the epidemic of failed new cams? [Re: dogdays] #1307332
09/20/12 06:20 PM
09/20/12 06:20 PM
3rd rock
K
kloyiod Offline
kloyiod  Offline
K
3rd rock
If your wiping a cam, your using the wrong company cause they won't back their product! I've never had a problem. http://www.hughesengines.com/TechArticles/ourcamsareguaranteednottogoflat.php
Re: Why the epidemic of failed new cams? [Re: DaytonaTurbo] #1307333
09/20/12 09:02 PM
09/20/12 09:02 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Yeah, that.
About 2 years ago I installed my first cam, a Hughes cam. Learned how to do it from moparts.com. Went just fine for me.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Why the epidemic of failed new cams? [Re: dogdays] #1307334
09/21/12 09:12 AM
09/21/12 09:12 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
R.
I don't think it's a bad idea to revisit these topics once in a while. It helps keep us updated on an ever changing subject and it makes it easier for guys (that this is a new problem to, like me) to get info on. I'm going through this right now (not a cam, but a lifter) and it's helpful (and sometimes confusing, lol) to get opinions...
Re: Why the epidemic of failed new cams? [Re: bobs66440] #1307335
09/21/12 09:20 AM
09/21/12 09:20 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I don't see the problem getting a flat tappet cam to live. I broke in a hyd flat last week and expect it to live a long life. MOST cam failures are due to installer error(NOT ALL!). Use a quality cam,lifters and oil and quit over thinking it.
Re: Why the epidemic of failed new cams? [Re: dogdays] #1307336
09/22/12 09:34 AM
09/22/12 09:34 AM
R.
Well, then, I don't want to see any more:
1. How good is a 440 Source (fill in the blank)...
2. Best rear main seal?...
3. Help! I have a bog in my carb coming off idle...
4. Edelbrock or Holley?
Re: Why the epidemic of failed new cams? [Re: Commando1] #1307337
09/22/12 10:04 AM
09/22/12 10:04 AM
bobs66440 Offline
bobs66440  Offline
R.
Exactly. Part of the reason for this forum is to help people with problems. That means revisiting popular topics now and then...
Re: Why the epidemic of failed new cams? [Re: bobs66440] #1307338
09/22/12 03:07 PM
09/22/12 03:07 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
This topic is one of those with varying strong opinions either way, and the tough part is, there is no data (that I'm aware of) to say
a) how many cams die
b) how the above cams die
I have run 3 hydraulic flat tappet cams in over the past 5 years, all had survived. If I had one of them bite the dust I'd probably be on the extreme of "never using one again" and go with a roller instead.
The whole problem is probably overblown. The fact that it results in significant work to fix, makes doing things right even more important and may exaggerate how common it actually is.
Just because everyone takes very careful steps to avoid it, doesn't automatically mean it's guaranteed to fail if you don't do things exactly by the book.
Re: Why the epidemic of failed new cams? [Re: Commando1] #1307339
09/22/12 07:19 PM
09/22/12 07:19 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
How many of the traditional, now considered lazy lobe, camshafts have failed? That was what this old stuff was originally designed to use.
It kind of reminds me of AR-15 discussions. People thought they knew better than Gene Stoner and strayed away from the original design. They were not always successful.
68 Roadrunner. 383 4-spd. Beat up.
Re: Why the epidemic of failed new cams? [Re: kloyiod] #1307340
09/22/12 07:43 PM
09/22/12 07:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thats Damn Funny Right There.....
https://board.moparts.org/ubbthreads/show...part=1&vc=1
Re: Why the epidemic of failed new cams? [Re: kloyiod] #1307341
09/22/12 08:09 PM
09/22/12 08:09 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Hee hee, I read this and said "he must be new here", 9 posts, guess so.
Don't be the exception.
