64 Dodge exhaust manifold what to use? #130680
10/01/08 01:29 PM
10/01/08 01:29 PM
michigan
black64 Offline OP
black64  Offline OP
michigan
I am in the process of putting a 440 in my 64 dodge 330 which had a slant 6. I been looking at headers so I know what will work with this combo but I also like having the cast HP manifolds as well. The max wedge manifolds are pricey. What would be the best cast HP exhaust manifold to use for my application? I have a 67 440 with 915 heads, calculated 10.35:1 compression, voodoo303 cam and 800 cfm carb.
Re: 64 Dodge exhaust manifold what to use? [Re: black64] #130681
10/01/08 01:52 PM
10/01/08 01:52 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Although I have not actually done it my self I believe the 1968-1970 high performance manifolda will work. Or if you want to put a 1967-70 B Body k frame in your car I know it will work. The later model K will set the engine back 11/2" or so.
Getting old just means you were smarter than some and luckier than others.
Re: 64 Dodge exhaust manifold what to use? [Re: dannysbee] #130682
10/01/08 02:38 PM
10/01/08 02:38 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
I used a set of 70 Hp manifolds on my 64 Plymouth w/440. Fit great and the car ran a best of 12.54 through tailpipes. Makes working on the car easy also.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 64 Dodge exhaust manifold what to use? [Re: 64dodge572] #130683
10/01/08 02:58 PM
10/01/08 02:58 PM
6T4 Polara Offline
6T4 Polara  Offline
HP manifolds on 426 wedge, engine in stock location no problems.Forgot have to raise engine to get passenger side on.
John
Re: 64 Dodge exhaust manifold what to use? [Re: 6T4 Polara] #130684
10/02/08 11:59 AM
10/02/08 11:59 AM
michigan
black64 Offline OP
black64  Offline OP
michigan
Thanks for the info I wanted to see what fit with using the 64 V8 kmember. More options the better chance on finding what I need.
