Finally my car works #1306775
09/19/12 04:00 AM
09/19/12 04:00 AM
Stockholm, Sweden
MrSixpack Offline OP
Stockholm, Sweden
Finally I found all the problems with my Challenger and got some good runs.
Talk about a bracket car, 5 runs within 4 hundreds of a second.
Best run was 9.81 and 137,5 mph
But my sixty foots are all over the place.
It does'nt matter how I adjust the shocks.
From 1.36 to 1.44, the best 60 feet is with foot braking and worst with transbrake.
When footbraking i stall to 2000 rpm then mash the throttle.
With transbrake I used 3000, 3200 and 3400 chip.
I don't know if I should go higher like 4000 on the brake
My chassi was built in 1974 so I might have to update it, still has ladderbar and leafsprings.
The car is amazing to drive, so nice and steady.
So finally after so many hours to sort it out, it paid of.
If I only could get the 60 feet down to 1.30 I would be glad
Now on to finish up my FED for next season, I will try to drive both cars next year.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Finally my car works [Re: MrSixpack] #1306776
09/19/12 07:26 AM
09/19/12 07:26 AM
gregsdart Online content
gregsdart  Online Content
Congrats on getting it consistant. The 1.36 is pretty good for a lot of cars in the mid/high nines. Does the car hook then spin if you raise the launch rpm? That indicates shocks need to be stiffer.
Re: Finally my car works [Re: gregsdart] #1306777
09/19/12 08:45 AM
09/19/12 08:45 AM
Stockholm, Sweden
Stockholm, Sweden
My car hooks real good, no spinning at all.
I have not tried higher start rpm then 3400 rpm.
With my old engine I used to leave att 5500 rpm.
But that engine had less power, around 100-125hp less.
In my class the standard is like 1.25 60 feet.
To bad I did'nt have any more rpm chips to try.
The car leaves lika a prostocker chassi vise, but slow.
No more BIG wheelstands.
http://www.facebook.com/photo.php?fbid=1...elevant_count=1
Re: Finally my car works [Re: MrSixpack] #1306778
09/19/12 10:30 AM
09/19/12 10:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would go up on the launch rpm... then based on how
it acts adjust it from there
Re: Finally my car works [Re: MrSixpack] #1306779
09/19/12 10:44 AM
09/19/12 10:44 AM
Az
Crizila Offline
Crizila  Offline
Az
Awesome!! Congrats!!
Fastest 300
