727 Housing Extension: Leaking Output Seal #1306279
09/18/12 07:59 AM
09/18/12 07:59 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I have the seal and once I get the front band adjusted (as explained in another thread), I am going to replace the output shaft seal that is in the housing extension. Replacing it I can do, but I am trying to determine why this seal needs replaced.
This is the third time that I have replaced this seal in 10-12 years. I don't drive the car allot each year and it just seems that I am replacing this seal way to often.
The first seal was the standard length seal and I also replaced the bushing. The second one is the one with the rubber boot. The one that I currently have is the standard seal again. The fluid is leaking out of the output shaft and going down the drive shaft and leaking down the differential assembly. I have splatter tranny fluid under my car from flinging off of the drive shaft.
Besides replacing the seal again, what else am I missing? Too much fluid? Input shaft OD damaged (it is nice and smooth but I will check it again), to much pressure in the tranny?
I don't know, I am just throwing out weird ideas.
Thanks again.
Re: 727 Housing Extension: Leaking Output Seal [Re: YO7_A66] #1306280
09/18/12 09:50 AM
09/18/12 09:50 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Use the booted seal , that is what was on it from the factory , that boot protects the seal itself from rod grime . How does the yoke look ? if the area where the seal rides is not smooth it's going to eat seals.
Also make sure the plug at the back of the yoke is not leaking .
Re: 727 Housing Extension: Leaking Output Seal [Re: JohnRR] #1306281
09/18/12 10:02 AM
09/18/12 10:02 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
John,
I will call and get the boot/seal on order. This is the one that is currently installed.
""Also make sure the plug at the back of the yoke is not leaking .""
I am not familiar with this plug. Where is it located?
Do you mean a plug on the yoke that is attached to the drive shaft?
Re: 727 Housing Extension: Leaking Output Seal [Re: YO7_A66] #1306282
09/18/12 10:08 AM
09/18/12 10:08 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
John's talking about the tin plug stuck in the u-joint end of the driveshaft yoke. Sometimes they can leak there. It was a common leak area on some chevs at dealer too. We used to clean, then epoxy the outside of it.
Re: 727 Housing Extension: Leaking Output Seal [Re: buildanother] #1306283
09/18/12 10:13 AM
09/18/12 10:13 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I never noticed one in there. Does anyone have a picture?
I will be able to pull the drive shaft in the next couple of days. This will give me some "heads-up" as to what to look for. I will hold off on the new seal until I can review the yoke.
Thanks guys!!
Re: 727 Housing Extension: Leaking Output Seal [Re: YO7_A66] #1306284
09/18/12 11:11 AM
09/18/12 11:11 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John,
The seal in this picture you attached is the booted seal, the boot is a tad shorter than the factory boot from in the day but it still does its job.
As said the plug is on the rear of the yoke
Re: 727 Housing Extension: Leaking Output Seal [Re: JohnRR] #1306285
09/18/12 11:21 AM
09/18/12 11:21 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
When I get the yoke/drive shaft removed, I will see if the plug is leaking. If so, then I will JB Weld it.
I was not even aware of this plug and that it could cause a leak. I will check it out.
Thanks allot!!
Re: 727 Housing Extension: Leaking Output Seal [Re: YO7_A66] #1306286
09/18/12 05:52 PM
09/18/12 05:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's a pic of the soft plug in the end of the slip yoke. It could be leaking around the plug or, in some rare cases, the plug has a small hole.
Re: 727 Housing Extension: Leaking Output Seal [Re: John_Kunkel] #1306287
09/18/12 08:44 PM
09/18/12 08:44 PM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
Great picture John.
I plan on pulling the drive shaft tomorrow night.
Thanks allot.
