518 tranny line question? #1306264
09/18/12 05:21 AM
09/18/12 05:21 AM
United states wisconsin
bigblockbryan Offline OP
okay in my 94 ram im putting together i have everything in place except one tranny line theres two lines. one is nut the other has like a brake line style flare and is there come kinda of nut im missing to hold this on thanks bryan
Re: 518 tranny line question? [Re: bigblockbryan] #1306265
09/18/12 04:36 PM
09/18/12 04:36 PM
Weatherford Texas
Greg Ducato Offline
Greg Ducato  Offline
Weatherford Texas
That is a "push in" style line,the shank below the flair seats on an o-ring in the fitting, the flair is retained by steel or plastic fingers inside the fiting to hold it in place. The cooler fittings can be found at the dealer or some transmission parts supply houses, make sure you know the thread size into the case, there is more than one. And do not overtighten, the cases are easy to crack.
Re: 518 tranny line question? [Re: Greg Ducato] #1306266
09/18/12 05:35 PM
09/18/12 05:35 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
A TSB came out about this PUSH IN fitting and what is involved to REPLACE it wit ha screw on fitting because they have been known to come apart ...
Re: 518 tranny line question? [Re: JohnRR] #1306267
09/18/12 07:05 PM
09/18/12 07:05 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Known to come apart & known to leak when reused too
