My 69 Valiant"s door wont open #1306126
09/18/12 02:52 AM
09/18/12 02:52 AM
Bismarck, ND USA
cageman Offline OP
cageman  Offline OP
Bismarck, ND USA
I tried to get out, pulled the handle, nothing, feels like its doing something, but nothing, I rolled the window down, pushed the outside button in, still nothing, move the lock up and down, makes no difference. The door is shut and just wont open. Has always worked fine. Today nothing.
Anyone have any pointers of what I need to look at here, and if the latch is fubar, does a 4 door latch work on a two door?
Re: My 69 Valiant"s door wont open [Re: cageman] #1306127
09/18/12 02:55 AM
09/18/12 02:55 AM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
It should be obvious once you look at it.
Taking the door panel off will be the hardest part.
Re: My 69 Valiant"s door wont open [Re: cageman] #1306128
09/18/12 07:23 AM
09/18/12 07:23 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Probably a plastic clip on the end of the linkage got brittle and broke off. I've never had the misfortune of neither inside or outside working. Latch itself is pretty durable, but they can get gummed up with stiff old grease. Some parts will be the same as 4 door, some won't.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: My 69 Valiant"s door wont open [Re: cageman] #1306129
09/18/12 11:17 AM
09/18/12 11:17 AM
Very likely. when you take off the panel & get in there as said you'll see what came apart. Should be an easy fix once you get in there
Re: My 69 Valiant"s door wont open [Re: GO_Fish] #1306130
09/19/12 12:07 AM
09/19/12 12:07 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
are your door hinges worn bad?? If the door is sagging, you may have to lift up on the door handle if the door is stuck on the striker.
Re: My 69 Valiant"s door wont open [Re: GO_Fish] #1306131
09/19/12 01:51 AM
09/19/12 01:51 AM
Bismarck, ND USA
cageman Offline OP
cageman  Offline OP
Bismarck, ND USA
Hinges are good, turned out to be just old dry grease that wouldnt allow the door lock mechanism to slide back and forth. Cleaned it all up, relubed and put it all back together tonight, works great. I also found the little screw that holds the outside push button together had worked loose, and allowed some extra slop, now I just tap the button and the door opens with ease. Also the button doesnt get stuck in any more. It was all metal clips and with the use of an old mirror, I was able to get it all apart and put back together. Luckily I got it all tore apart and back together again before the sun went down.
