Trans brake question. #1305968
09/17/12 10:21 PM
09/17/12 10:21 PM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
If my reaction times go from .00X's to .070's consistently, and I've checked everything else out thoroughly, is it possible my Griner trans brake solenoid could be lazy releasing? It's been on the car for at least 10 years so it has some mileage on it. My only other possibility is the B&M button is sticking.
Re: Trans brake question. [Re: 10sec440] #1305969
09/18/12 12:32 AM
09/18/12 12:32 AM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
I would be more inclined to think its not the brake , I have used Griner brake for as long without issues , give Steve ( at Griner ) a call he will tell you the same thing . I use a Biondo adjustable button , I have had the lock nut come loose and do what your saying .
Re: Trans brake question. [Re: Gabby63] #1305970
09/18/12 01:38 AM
09/18/12 01:38 AM
Renton Washington
Triple Threat Offline
Renton Washington
Another member here might respond, he was having issues with reaction times and 60 foots varying, he changed the transbrake solenoid and the problems went away.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Trans brake question. [Re: 10sec440] #1305971
09/18/12 02:55 AM
09/18/12 02:55 AM
WA
JD Dart Offline
JD Dart  Offline
WA
I have the A&A brake just put in a new solenoid. My problem was all year the car would 60' different, when it was cold 60' were better.
Once it had higher temp after 1st rd the 60' went away. Tried new tires different convertor changed the 4 link and shock settings. Never could get a handle on it finally did some full out passes normally run super street. On the first two time trials wheel speed went to 37 mph then first rd wheel speed went to 20 mph for .120 of a second then up to 38
2nd rd went to 10 mph held there for same time then shoot up to 38. Replaced solenoid and cleaned the valve body all the problems went away car pickup .10 and had to add .021 delay to the box from 1.033 to 1.054
When I took the solenoid apart the piston looked like it someone sand blasted it, this was only in the car for 2 years
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Trans brake question. [Re: JD Dart] #1305972
09/20/12 07:21 PM
09/20/12 07:21 PM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Anybody else have any input? I use a B&M non adjustable button. Thanks.
Re: Trans brake question. [Re: 10sec440] #1305973
09/20/12 07:34 PM
09/20/12 07:34 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i would try a new button first as gabby suggested. see if that helps.
Re: Trans brake question. [Re: 10sec440] #1305974
09/20/12 08:04 PM
09/20/12 08:04 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Check/clean all electrical connections in that circuit. Replace any wires that are suspect. It's not the same problem but a local racer was having trouble with his brake not working at the starting line. It worked when tested everywhere else. After several weeks of frustration he finally found a wire that was broken inside the insulation, making intermittant contact. That stuff doesn't last forever in a high-vibration environment.
Re: Trans brake question. [Re: @#$%&*!] #1305975
09/20/12 08:34 PM
09/20/12 08:34 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
There are quite a few possibilities, have you removed and cleaned the valve body ?? Dirt can be a big problem to the valve body, I don't like letting them go for more than a couple years without at least taking the valve body apart and cleaning, that includes the solenoid valve. Electrical issues could be connection, or solenoid. Issues like this could also be deeper in the trans, like sealing rings to the high drum or even the pump, or a leaking issue anywhere in the trans. Have you checked your pressures? If I was a bettin' man (and I'm a bracket racer so I am) I would first remove the valve body, take it apart clean it, make sure all valves are moving freely and functioning correctly, I would guess an 80% chance that's it.
If you want it consistant you gotta keep it clean.
Re: Trans brake question. [Re: @#$%&*!] #1305976
09/21/12 09:30 PM
09/21/12 09:30 PM
Mission BC
10sec440 Offline OP
10sec440  Offline OP
Mission BC
Thanks guys, I will go through it and clean it out. I have a buddy who will lend me a solenoid also to make sure. I'm leading the points by ONE point at my local track and with one race weekend left I need to be sure I'm not going there to cut .070 lights!
