Re: Trans brake question.
[Re: Gabby63]
#1305970
09/18/12 01:38 AM
09/18/12 01:38 AM
Triple Threat
Renton Washington
Another member here might respond, he was having issues with reaction times and 60 foots varying, he changed the transbrake solenoid and the problems went away.
[Re: 10sec440]
#1305971
09/18/12 02:55 AM
09/18/12 02:55 AM
Posts: 740 WA
JD Dart
WA
I have the A&A brake just put in a new solenoid. My problem was all year the car would 60' different, when it was cold 60' were better. Once it had higher temp after 1st rd the 60' went away. Tried new tires different convertor changed the 4 link and shock settings. Never could get a handle on it finally did some full out passes normally run super street. On the first two time trials wheel speed went to 37 mph then first rd wheel speed went to 20 mph for .120 of a second then up to 38 2nd rd went to 10 mph held there for same time then shoot up to 38. Replaced solenoid and cleaned the valve body all the problems went away car pickup .10 and had to add .021 delay to the box from 1.033 to 1.054 When I took the solenoid apart the piston looked like it someone sand blasted it, this was only in the car for 2 years
best so far 8.53 @ 158.59 MPH 60'1.240
[Re: 10sec440]
#1305974
09/20/12 08:04 PM
09/20/12 08:04 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
Anybody else have any input? I use a B&M non adjustable button. Thanks.
Check/clean all electrical connections in that circuit. Replace any wires that are suspect. It's not the same problem but a local racer was having trouble with his brake not working at the starting line. It worked when tested everywhere else. After several weeks of frustration he finally found a wire that was broken inside the insulation, making intermittant contact. That stuff doesn't last forever in a high-vibration environment.
[Re: @#$%&*!]
#1305975
09/20/12 08:34 PM
09/20/12 08:34 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
There are quite a few possibilities, have you removed and cleaned the valve body ?? Dirt can be a big problem to the valve body, I don't like letting them go for more than a couple years without at least taking the valve body apart and cleaning, that includes the solenoid valve. Electrical issues could be connection, or solenoid. Issues like this could also be deeper in the trans, like sealing rings to the high drum or even the pump, or a leaking issue anywhere in the trans. Have you checked your pressures? If I was a bettin' man (and I'm a bracket racer so I am) I would first remove the valve body, take it apart clean it, make sure all valves are moving freely and functioning correctly, I would guess an 80% chance that's it.
If you want it consistant you gotta keep it clean.
