Question On 7AL Box
#1305536
09/17/12 11:01 AM
09/17/12 11:01 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I know its happened to me years ago BUT I forget... if you hook the dist wires up backwards what occurs, will you get a miss towards the higher rpm... this is a MSD 6al box thanks
Re: Question On 7AL Box
[Re: MR_P_BODY]
#1305537
09/17/12 11:57 AM
09/17/12 11:57 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
I have heard this but I have no personal experience.
[Re: MR_P_BODY]
#1305538
09/17/12 01:10 PM
09/17/12 01:10 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Have seen it cause different problems. The high RPM miss was the problem I saw first time I encountered the wires being crossed. Other problems were hard starting, SEVERE kick-back. Also, have seen them start OK but when the timing light was hooked up, it would show massive advance or very irratic timing. The leads on the pick-up coil should be orange&black and black with violet tracer. The wires in the harness from box to distributor should be green and violet. The violet does NOT go to the violet tracer!! The solid violet wire goes to the orange&black(+). Also, be sure to peel back the black protective sheathing on the wires coming out of the box. I have seen them crossed in the connector there too. Basically, I guess there are 4 places that they could be crossed.
If you like drag racing, support your local track.
[Re: 67mprfan]
#1305540
09/17/12 03:57 PM
09/17/12 03:57 PM
Posts: 2,177 ill
dennismopar73
ill
If your timing seems to be jumping all over the place, check the following items:
What kind of timing light are you using? Many lights have trouble reading the MSD's capacitive discharge multiple sparks. Dial back timing lights are not recommended. Try another non-adjustable light and check the timing again. MSD offers a Timing Light, PN 8990. Make sure you are not using Solid Core wires. Inspect the routing of the Magnetic Pickup Harness. It should be routed clear of the coil primary wires and plug wires. It is best to route it along a ground plain such as the firewall, frame or engine block to form a shield around it, or replace the Black magnetic pickup cable with a shielded Gray cable PN 8862, which has a ground wire on one end. Check the polarity of the magnetic pickup wires of the distributor. Reverse the connectors and check the timing again. For Analog ignitions the correct polarity is whichever orientation gives the most retarded timing. For Digital Ignitions the correct polarity is whichever orientation give the most advanced timing. On Chevrolet engines, if the timing is retarding inspect for cam-walk. This is especially prevalent on engines with a chrome or stock type replacement timing chain cover that is actually bowing forward allowing the cam to "walk", due to thin stamping. To check this, wedge something in-between the water pump and timing chain cover to keep the camp from walking. If this corrects the timing fluctuation, replace the timing chain cover. Worn distributor gear, inspect the distributor gear for excess wear or incorrect gear mesh if the gear is riding too high or too low on the cam gear. If correct the wear pattern should show the gear mesh in the center of the gear.
[Re: CHAPPER]
#1305543
09/17/12 10:17 PM
09/17/12 10:17 PM
MR_P_BODY
I have some aftermarket dist(I forget what brand, it could be a MP unit)... the colors are yellow and black so I went with yellow as the + but on the dyno I had a (we will call it a break up) break up or a slight miss...It was suggested it might be the valve springs but I have my doubts(the springs have 255# on seat and at least 600# at .550 but thats as far as my gauge goes)on that being the issue...it started at about 5500 rpm and the first pull didnt show it but each pull after that did... the timing is a bit more than I would have expected at 38*....so thats why I brought up this question.... I wont be able to test this till I get the engine back into the car and flip them both ways to see what occurs
[Re: 67mprfan]
#1305546
09/18/12 07:15 PM
09/18/12 07:15 PM
Posts: 20,202 Park Forest, IL
slantzilla
Park Forest, IL
Reversing the wires changes where the pickup reads the reluctor. When they are correct it reads the front edge, reversed it reads the back edge. It will change your timing almost 30 degrees. (Or at least it did mine)
[Re: Cab_Burge]
#1305549
09/19/12 12:45 AM
09/19/12 12:45 AM
MR_P_BODY
6AL or 7AL
It was a 6AL on the dyno but I have a 7AL in the car but I cant see them being any different if the wires are backwards
