Question On 7AL Box #1305536
09/17/12 11:01 AM
09/17/12 11:01 AM
MR_P_BODY Offline OP
I know its happened to me years ago BUT I forget...
if you hook the dist wires up backwards what occurs,
will you get a miss towards the higher rpm... this
is a MSD 6al box
thanks
Re: Question On 7AL Box [Re: MR_P_BODY] #1305537
09/17/12 11:57 AM
09/17/12 11:57 AM
Guitar Jones Offline
I have heard this but I have no personal experience.
Re: Question On 7AL Box [Re: MR_P_BODY] #1305538
09/17/12 01:10 PM
09/17/12 01:10 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Have seen it cause different problems. The high RPM miss was the problem I saw first time I encountered the wires being crossed. Other problems were hard starting, SEVERE kick-back. Also, have seen them start OK but when the timing light was hooked up, it would show massive advance or very irratic timing. The leads on the pick-up coil should be orange&black and black with violet tracer. The wires in the harness from box to distributor should be green and violet. The violet does NOT go to the violet tracer!! The solid violet wire goes to the orange&black(+). Also, be sure to peel back the black protective sheathing on the wires coming out of the box. I have seen them crossed in the connector there too. Basically, I guess there are 4 places that they could be crossed.
If you like drag racing, support your local track.
Re: Question On 7AL Box [Re: CHAPPER] #1305539
09/17/12 03:23 PM
09/17/12 03:23 PM
ohio
67mprfan Online content
67mprfan  Online Content
ohio
I guess i need to check my wiring because even when cold it's has kick back also show 40+ on timimg
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Question On 7AL Box [Re: 67mprfan] #1305540
09/17/12 03:57 PM
09/17/12 03:57 PM
ill
dennismopar73 Offline
ill
If your timing seems to be jumping all over the place, check the following items:
What kind of timing light are you using? Many lights have trouble reading the MSD's capacitive discharge multiple sparks. Dial back timing lights are not recommended. Try another non-adjustable light and check the timing again. MSD offers a Timing Light, PN 8990.
Make sure you are not using Solid Core wires.
Inspect the routing of the Magnetic Pickup Harness. It should be routed clear of the coil primary wires and plug wires. It is best to route it along a ground plain such as the firewall, frame or engine block to form a shield around it, or replace the Black magnetic pickup cable with a shielded Gray cable PN 8862, which has a ground wire on one end.
Check the polarity of the magnetic pickup wires of the distributor. Reverse the connectors and check the timing again. For Analog ignitions the correct polarity is whichever orientation gives the most retarded timing. For Digital Ignitions the correct polarity is whichever orientation give the most advanced timing.
On Chevrolet engines, if the timing is retarding inspect for cam-walk. This is especially prevalent on engines with a chrome or stock type replacement timing chain cover that is actually bowing forward allowing the cam to "walk", due to thin stamping. To check this, wedge something in-between the water pump and timing chain cover to keep the camp from walking. If this corrects the timing fluctuation, replace the timing chain cover.
Worn distributor gear, inspect the distributor gear for excess wear or incorrect gear mesh if the gear is riding too high or too low on the cam gear. If correct the wear pattern should show the gear mesh in the center of the gear.
Re: Question On 7AL Box [Re: dennismopar73] #1305541
09/17/12 03:58 PM
09/17/12 03:58 PM
ill
ill
The magnetic pickup in MSD Distributors can also be checked with an Ohm meter to make sure it is within operating specifications. Once again, connect the Ohm meter's leads to the two terminals of the pickup. The resistance should be within 500 - 700 ohms. If the resistance is out of this specification, inspect the condition of the wires leading to the pickup for abrasion, shorting or opens. If the wiring is okay, the pickup is at fault.
NOTE: The Ignition will check good if the pickup is at fault. Follow the Checking for Spark procedure.
Re: Question On 7AL Box [Re: dennismopar73] #1305542
09/17/12 04:02 PM
09/17/12 04:02 PM
ill
ill
Some aftermarket vacuum canisters are adjustable through the vacuum port.On the dist!
Re: Question On 7AL Box [Re: CHAPPER] #1305543
09/17/12 10:17 PM
09/17/12 10:17 PM
I have some aftermarket dist(I forget what brand, it
could be a MP unit)... the colors are yellow and black
so I went with yellow as the + but on the dyno I had
a (we will call it a break up) break up or a slight
miss...It was suggested it might be the valve springs
but I have my doubts(the springs have 255# on seat
and at least 600# at .550 but thats as far as my
gauge goes)on that being the issue...it started at
about 5500 rpm and the first pull didnt show it but
each pull after that did... the timing is a bit more
than I would have expected at 38*....so thats why
I brought up this question.... I wont be able to
test this till I get the engine back into the car
and flip them both ways to see what occurs
Re: Question On 7AL Box [Re: MR_P_BODY] #1305544
09/17/12 10:40 PM
09/17/12 10:40 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I was 'asssuming' you had a MSD distributor with the box...the colors I gave you for the pick-up coil would not be correct in your case. I would say you have the right idea. When the motor is back in the car, try switching the wires like you said. This is a typical situation where the wires do get switched easily,,,having different type connectors that will not plug together and making connections other ways.
Re: Question On 7AL Box [Re: CHAPPER] #1305545
09/18/12 04:03 PM
09/18/12 04:03 PM
ohio
ohio
would it be an issue if i'm using a stock dist with vacuumm canister removed and locked out
Re: Question On 7AL Box [Re: 67mprfan] #1305546
09/18/12 07:15 PM
09/18/12 07:15 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Reversing the wires changes where the pickup reads the reluctor. When they are correct it reads the front edge, reversed it reads the back edge. It will change your timing almost 30 degrees. (Or at least it did mine)
Re: Question On 7AL Box [Re: slantzilla] #1305547
09/18/12 08:28 PM
09/18/12 08:28 PM
michigan woods
imfixinmopars426 Offline
michigan woods
i have switched wires on msd,and orange box's,and i usually got a miss around 3500,and engine sounded "lazy". engines didnt sound like they wanted to go 5500 or even close...
Re: Question On 7AL Box [Re: MR_P_BODY] #1305548
09/19/12 12:37 AM
09/19/12 12:37 AM
6AL or 7AL
Re: Question On 7AL Box [Re: Cab_Burge] #1305549
09/19/12 12:45 AM
09/19/12 12:45 AM
6AL or 7AL
It was a 6AL on the dyno but I have a 7AL in the car
but I cant see them being any different if the wires
are backwards
Re: Question On 7AL Box [Re: MR_P_BODY] #1305550
09/19/12 12:53 AM
09/19/12 12:53 AM
If you reverse the polarity on the mag pickup wires it will change the timing 40 degrees and if you change the timing it will run like crap under a load
