300M fuel pressure drop #1304885
09/16/12 05:49 PM
09/16/12 05:49 PM
Rancho Cucamonga,Ca
3
392charger Offline OP
Rancho Cucamonga,Ca
Hey all,
My 2000 300M with 157,000 miles has a hard start issue, takes two cycles of the igniton to fire after sitting for a moment. I checked the fuel preesure while the engine is running and found it drops from 55 lbs to zero the second the engine is shut down. Bad check valve? Where is it and can it be fixed or is it time for a new pump? Thanks in advance for any suggestions.
Re: 300M fuel pressure drop [Re: 392charger] #1304886
09/16/12 07:05 PM
09/16/12 07:05 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Its the regulator in the fuel pump module . Unless you got an injector leaking down or major fuel leak, its time for a fuel pump module.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 300M fuel pressure drop [Re: 71yelladustr] #1304887
09/16/12 07:19 PM
09/16/12 07:19 PM
Rancho Cucamonga,Ca
3
Rancho Cucamonga,Ca
Thanks yelladuster. Is the fuel pump module under the hood or part of the pump itself in the tank?
Re: 300M fuel pressure drop [Re: 392charger] #1304888
09/16/12 09:47 PM
09/16/12 09:47 PM
Missouri U.S.A.
Missouri U.S.A.
Its the pump unit in the tank.
10.02@134
Re: 300M fuel pressure drop [Re: 71yelladustr] #1304889
09/16/12 09:51 PM
09/16/12 09:51 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
You didn't need to hear that!!! (WTH do they put fuel pumps INSIDE the fuel tanks anymore?)
Re: 300M fuel pressure drop [Re: Sunroofcuda] #1304890
09/16/12 10:58 PM
09/16/12 10:58 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
At least it's not a camaro. It's not a bad job and the tank should even have a drainplug, or at least my 2000 intrepid did. Have to pop lower rear seat cushion to unplug harness IIRC.
Re: 300M fuel pressure drop [Re: buildanother] #1304891
09/17/12 11:59 PM
09/17/12 11:59 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Yep if it drops right to zero it sounds like the pump as a leaking inj wont usually drop that fast. And since its a returnless system it would be the valve in the pump. I remember some year intrepids had a plate in the trunk you could remove to get the pump out. I dont think your 300 has that so you will have to drop the tank some. Ron
