71 Hemi Power Steering Pump #1304808
09/16/12 03:10 PM
09/16/12 03:10 PM
Wisconsin
Mopar_Mudder Offline OP
Wisconsin
Can anyone tell me if either of these is correct for a 1971 Hemi Cuda?
1971 Hemi Cuda 2005 SRT-10 Regular Cab Flame Red. 12.771 @ 109.67<---TIME SLIP--Video
Re: 71 Hemi Power Steering Pump [Re: Mopar_Mudder] #1304809
09/16/12 03:12 PM
09/16/12 03:12 PM
Wisconsin
Wisconsin
pump2
Re: 71 Hemi Power Steering Pump [Re: Mopar_Mudder] #1304810
09/16/12 03:23 PM
09/16/12 03:23 PM
Rancho Cordova, California (Sa...
hemi71x Online content
hemi71x  Online Content
If #2 has a correct "hemi" pulley on the pump, that's the one.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: 71 Hemi Power Steering Pump [Re: hemi71x] #1304811
09/16/12 04:14 PM
09/16/12 04:14 PM
Wisconsin
Wisconsin
Any easy wall to tell if it is the right pulley, other then bolt it on and see if it fits?
Re: 71 Hemi Power Steering Pump [Re: Mopar_Mudder] #1304812
09/16/12 04:42 PM
09/16/12 04:42 PM
Can't help you with that question.
It's an old picture of mine.
Sold the car 8 years ago.
Year One sells repop pulleys.
Maybe they give measurements, on their catalog page.
Some other member possibly can chime in, and help you out.
Re: 71 Hemi Power Steering Pump [Re: hemi71x] #1304813
09/17/12 03:19 PM
09/17/12 03:19 PM
Wisconsin
Wisconsin
Would anyone have the following dimension for a 1971 cuda or challenger with Hemi? Or even a RB motor would help narrow down if it is right or wrong.
Re: 71 Hemi Power Steering Pump [Re: Mopar_Mudder] #1304814
09/17/12 06:30 PM
09/17/12 06:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Do you have pump #1 also ? if so compare the offset as #1 appears to be a B RB pump , or at least the pulley is ...
Re: 71 Hemi Power Steering Pump [Re: JohnRR] #1304815
09/17/12 06:44 PM
09/17/12 06:44 PM
Wisconsin
Wisconsin
I have neither at this point, looking at buying #2 but want to make sure it has correct pulley first.
Re: 71 Hemi Power Steering Pump [Re: Mopar_Mudder] #1304816
09/17/12 07:55 PM
09/17/12 07:55 PM
Since you don't have either a "hemi" pulley as in picture #2, and a regular B & RB pulley in picture #1, my thoughts would be to use the regular Power steering pump pulley from the B & RB engines, and 2 groove crank pulley, from the same.
You have the thin balancer on the engine, so you would be better off going that route, instead of going the spacer route, in your other posting.
At my storage locker i have lots of Federal pumps, brackets, pulleys, that you might be interested in.
Re: 71 Hemi Power Steering Pump [Re: hemi71x] #1304817
09/17/12 10:07 PM
09/17/12 10:07 PM
Wisconsin
Wisconsin
I want to keep on the correct pulleys and pump on the engine it my reasoning for wanting to make it work. I have an RB pump and pulley that I measured and it is 2.37" from water pump housing mouning surface to the center line of pulley. The #2 pump I pictured I found out is 2.75" so I think it is the correct pump as the Hemi pulley is suppose to stick out a little further then the RB pulley.
I also accuratley measured everything tonight and I need a .717 spacer to line the crank up with water pump pulley. Doing that I have exactly 2.754" from water pump housing mount to center of Steering groove on the crank. That is pretty darn cloe to 2.75 that the pump measures.
I found where I can get a .70 spacer pretty reasonable which is problably close enough. They also have a 1" I could get and turn it down to .717. Going to double check my numbers and order one.
