carb stock jets #1304759
09/16/12 01:53 PM
09/16/12 01:53 PM
SW pa
goldenlancer Offline OP
SW pa
what are the stock jet sizes for 750 edlebrock carbs what color should the plugs be with pump gas in a 500 inch motor with an indy 2x4 intake I can't seem to get it close. Bill
N/SS
Re: carb stock jets [Re: goldenlancer] #1304760
09/16/12 01:57 PM
09/16/12 01:57 PM
The question is which part number Eddy carbs?
Re: carb stock jets [Re: Cab_Burge] #1304761
09/16/12 02:01 PM
09/16/12 02:01 PM
SW pa
SW pa
1407
N/SS
Re: carb stock jets [Re: goldenlancer] #1304762
09/16/12 02:05 PM
09/16/12 02:05 PM
Idaho
LaRoy Engines Offline
Idaho
On unleaded pump gas the plug porcelain should be white with a grey line about 1/16" wide down where the porcelain cements to the iron body.
Re: carb stock jets [Re: LaRoy Engines] #1304763
09/16/12 02:13 PM
09/16/12 02:13 PM
SW pa
SW pa
with rnc 9y plugs they are a light to dark brown. timing is set at 40* locked in MSD with a 6al 2 box. that's where the motor seems to run the best. im running 100 in the front and 95 in the rear
Re: carb stock jets [Re: goldenlancer] #1304764
09/16/12 03:03 PM
09/16/12 03:03 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Metering rods will make a difference too.
Stock 1407 setup is .113 front with a .071/.047 metering rod,and a .107 rear jet.
Keith
Re: carb stock jets [Re: goldenlancer] #1304765
09/16/12 06:17 PM
09/16/12 06:17 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
have you tried less timing?
Re: carb stock jets [Re: Plymouth340] #1304766
09/16/12 07:13 PM
09/16/12 07:13 PM
SW pa
SW pa
tryed less timing and the car slowes down.every 2 degrees it slows 3 tenths. Bill
N/SS
