ET Improvement Removing Choke Horn From 850 DP? #1304276
09/15/12 12:24 PM
09/15/12 12:24 PM
Indiana
Cuda_Mike Offline OP
Indiana
Has anyone compared et/performance by removing choke horn on a standard 850 dp (4781?) with no other changes?
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: Cuda_Mike] #1304277
09/15/12 12:37 PM
09/15/12 12:37 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i didnt notice a thing on my 10.50 et car.its the only thing i did.i put a 1050 8896 dominator on it and picked up to 10.40.but i think the 850 was way to small to begin with.
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: Cuda_Mike] #1304278
09/15/12 12:42 PM
09/15/12 12:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All I remember is that there was a change(slight)
but I cant remember the numbers... that was years ago
when I cut the carb... still using it now on my
418 engine
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: MR_P_BODY] #1304279
09/15/12 02:04 PM
09/15/12 02:04 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The biggest improvement I remember was a 20-30 cfm gain..........
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: Cuda_Mike] #1304280
09/15/12 02:30 PM
09/15/12 02:30 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Looking at the pic,,are you running this carb/pan set-up now?? Is it working OK? If it is working OK now, I might not take the tower off. It appears that without the choke tower, your carb is going to be the same height as the pan and hood scoop opening. The tower might be saving you from problems right now.
If you like drag racing, support your local track.
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: CHAPPER] #1304281
09/15/12 02:43 PM
09/15/12 02:43 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Haven't run any ET tests, but the 4781 on my Duster sits like the OP's photo, has a milled choke horn, and I've had no problems. Milling the choke horn off improves CFM and feeds air into the carb more efficiently than having it shrouded by the choke tower. I wouldn't expect much ET out of it, but I'd bet the MPH would pick up a little from the improvement in mixture distribution.
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: topside] #1304282
09/15/12 06:31 PM
09/15/12 06:31 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have been thinking about milling my choke air horn off also. Ron
Re: ET Improvement Removing Choke Horn From 850 DP? [Re: 383man] #1304283
09/15/12 06:55 PM
09/15/12 06:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Why waste your time on that small block carb............get a Dominator and be done with it........
