front pump bushing - babbit or bronze? #1303660
09/14/12 10:41 AM
09/14/12 10:41 AM
Mesa, AZ
cagebob1 Online content OP
cagebob1  Online Content OP
Mesa, AZ
Finally got around to freshening the trans in my cuda. what is the best choice in bushing material for the front pump bushing? and why?
It's only a 12 second car that doesn't see any street use anymore.
Where is a good place to get auto trans parts?
Re: front pump bushing - babbit or bronze? [Re: cagebob1] #1303661
09/14/12 11:00 AM
09/14/12 11:00 AM
Babbit is the only way to go--it will not damage the hub metal like the bronze factory style can--it also conforms to smallamounts of- out of round, off center etc present in almost all aftermarket converters--the hubs used in aftermarket units seems softer than factory to me--Bronze ( tough, hard) equals trouble--always , always go with babbit on pump bushing IMO and experience
Re: front pump bushing - babbit or bronze? [Re: ] #1303662
09/14/12 06:13 PM
09/14/12 06:13 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I know all the race converter company's want you to use babbit which is fine and if they call for it I will use 1 just in case there is a warranty issue,but I have installed literally hundreds of the factory bronze one's with great success.
I have been into units I did that had 100k on them and the hub still look good.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: front pump bushing - babbit or bronze? [Re: dusturbd340W5] #1303663
09/14/12 09:01 PM
09/14/12 09:01 PM
Guitar Jones Offline
Depends on the material, if it's CM I use the factory bronze, if not use the babbit.
Re: front pump bushing - babbit or bronze? [Re: Guitar Jones] #1303664
09/15/12 12:38 AM
09/15/12 12:38 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Most of the converters I have bought over the years usually come with a babbit bushing in the box. So I just install the babbit bushing and use it. Ron
