when timing gears wear does the cam adv. or ret? #1303226
09/13/12 12:40 AM
09/13/12 12:40 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
my rollmaster timing set is wore out. the gears wore and not the chain. which way would the cam timing go adv or ret with worn out gears?
Re: when timing gears wear does the cam adv. or ret? [Re: mopar dave] #1303227
09/13/12 01:26 AM
09/13/12 01:26 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
The cam timing will retard.
Re: when timing gears wear does the cam adv. or ret? [Re: super451b] #1303228
09/13/12 09:16 AM
09/13/12 09:16 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: when timing gears wear does the cam adv. or ret? [Re: Dodgem] #1303229
09/13/12 09:36 AM
09/13/12 09:36 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I disagree.
The timing will be eratic.
Re: when timing gears wear does the cam adv. or ret? [Re: Commando1] #1303230
09/13/12 10:57 AM
09/13/12 10:57 AM
Mt Morris Michigan
Mt Morris Michigan
ok thanks. still gettin adv. degree readings below 100*. put my old rollmaster set back on just to see if it was anywhere near the 103* i had it at when fisrt installed. i now get 96*.
Re: when timing gears wear does the cam adv. or ret? [Re: Commando1] #1303231
09/13/12 11:46 AM
09/13/12 11:46 AM
MN
hemidup Offline
hemidup  Offline
MN
I disagree.
Just had a cutomer come in for a tune up. It was a totally stock 383 with lots of miles. Put the timing light on it and the timing mark was jumping all over the place at rpm. A new timing gear set took care of that issue.
Also, as chains stretch and gears wear it will retard the timing which is why some cam manufactures add in +4.
Jerry Williams.
Re: when timing gears wear does the cam adv. or ret? [Re: hemidup] #1303232
09/13/12 12:18 PM
09/13/12 12:18 PM
Mt Morris Michigan
Mt Morris Michigan
ok, just spoke with bullet cams about time issue with all my readings being advanced(below 100*). they told me something simular to what Mike told me to try. bar crank to intake open point i want(33*) and them rotate cam to .50" open and install chain.
