aluminum bumper brackets #1302998
09/12/12 06:02 PM
09/12/12 06:02 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
does anybody make theese for a 68 cuda?
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: aluminum bumper brackets [Re: Old School] #1302999
09/12/12 06:46 PM
09/12/12 06:46 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
Im gonna make a set for my own car, a 67. Maybe I can make 2 sets?
Re: aluminum bumper brackets [Re: domingo] #1303000
09/12/12 10:06 PM
09/12/12 10:06 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Make 3 sets please
Re: aluminum bumper brackets [Re: domingo] #1303001
09/12/12 10:22 PM
09/12/12 10:22 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
domingo, when you make them, take a pic and post it. thanks
Re: aluminum bumper brackets [Re: Old School] #1303002
09/13/12 09:20 AM
09/13/12 09:20 AM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
somebody post a pic and dimensions of original ones. Lot of us out here who could probably make them.
Re: aluminum bumper brackets [Re: crazyjjk] #1303003
09/13/12 09:31 AM
09/13/12 09:31 AM
fullmetaljacket Offline
I made a set of both the fronts and the rears for a friends 68' Cuda, and let me tell you, it isn't fun. Interesting yes because of the special compound bends and radius twist on the mounting surfaces that if not made correctly, will not work.
Saved over 14 pounds if I remember correctly. They went on like stock as I wiped the sweat off my forehead.
No, I will not make other sets because it takes too much time and labor plus the material to be co$t effective. A jig would make it easier to venture into. Not enough time in my hectic schedule, but good luck every one.
Re: aluminum bumper brackets [Re: fullmetaljacket] #1303004
09/13/12 04:53 PM
09/13/12 04:53 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
please make me a set, pretty please...
Re: aluminum bumper brackets [Re: Old School] #1303005
09/13/12 05:11 PM
09/13/12 05:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I made a set years ago out of .100 alum to hold my
plastic bumper(plastic not fiberglass) that I vac-
formed... the bumper and mounts was 5.7#... that was
on my 69 Valiant 100... they're pretty easy to make
Re: aluminum bumper brackets [Re: MR_P_BODY] #1303006
09/13/12 08:33 PM
09/13/12 08:33 PM
metro detroit
turner Offline
turner  Offline
metro detroit
Bought these from Mystical cuda if I remember correctly, also came with a chromed fiberglass bumper.......these brackets are truly a work of art, they were built on a jig and as stated they are alot more complex than you would think.
Re: aluminum bumper brackets [Re: turner] #1303007
09/13/12 08:36 PM
09/13/12 08:36 PM
metro detroit
turner Offline
turner  Offline
metro detroit
they were a special build, not a product that is offered for purchase, just to clarify that ............although they might remember who fabbed them up, they were built somewhere in Washington State I believe
Re: aluminum bumper brackets [Re: turner] #1303008
09/13/12 08:37 PM
09/13/12 08:37 PM
metro detroit
turner Offline
turner  Offline
metro detroit
Fabbed from 1/8" aluminum
Re: aluminum bumper brackets [Re: turner] #1303009
09/13/12 08:55 PM
09/13/12 08:55 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
turner, your just teasing us.....
Re: aluminum bumper brackets [Re: Old School] #1303010
09/13/12 09:22 PM
09/13/12 09:22 PM
bronx n.y
O
O
bronx n.y
Please don't 4 get about me
Re: aluminum bumper brackets [Re: turner] #1303011
09/13/12 11:37 PM
09/13/12 11:37 PM
Those are beautiful and by the construction, the multi-welded pieces takes the hard work out of the equation. Mine were done using one piece of Aluminum and hand formed at every bend and elevation to conform to a stock fit. Remember that there are many grades of Aluminum hardness and softness. The right alloy has to be used to hold out, though in an accident, even the steel ones don't do so well.
If this mad science of weight loss was my life shift, I would have made every bracket available already. Lots of work that only can happen with passion. Now if only I can cook up a set of Aluminum doors for the early B's. LOL. AMD is asleep at the controls.
Re: aluminum bumper brackets [Re: fullmetaljacket] #1303012
09/13/12 11:46 PM
09/13/12 11:46 PM
Muncie
Racebuddy Offline
Racebuddy  Offline
Muncie
Totally Sweeeet
Re: aluminum bumper brackets [Re: fullmetaljacket] #1303013
09/14/12 02:10 AM
09/14/12 02:10 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Use 6061T6 and weld it, you can form other grades but the T6 is too hard. Its also easier to bend in a press brake with large dies. 60 ton would work. Tim
Re: aluminum bumper brackets [Re: one bad fish] #1303014
09/14/12 06:31 AM
09/14/12 06:31 AM
metro detroit
turner Offline
turner  Offline
metro detroit
judging by your pic, you look like you need the steel brackets........that is a giant wheelstand, hopefully when I get a new convertor mine will launch like yours
Re: aluminum bumper brackets [Re: turner] #1303015
09/14/12 06:38 AM
09/14/12 06:38 AM
bronx n.y
O
O
bronx n.y
U don't want it to leave like that it looks good but hard on parts. Lol
Re: aluminum bumper brackets [Re: one bad fish] #1303016
09/14/12 12:54 PM
09/14/12 12:54 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Unlimited Fiberglass shows fiberglass bumper brackets available. http://www.up22.com/barracuda.htm#BARRACUDA 67-69
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
