Adding a power brake kit to a manual brake system #1302796
09/12/12 09:55 AM
09/12/12 09:55 AM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
I have an A-Body with no room for a power brake booster. I have heard of a power brake kit that can be added somewhere under the car in the frame area. Any input would be greatly appreciated.
Re: Adding a power brake kit to a manual brake system [Re: 62BT409] #1302797
09/12/12 10:17 AM
09/12/12 10:17 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Why is there no room for a power brake booster ?
Re: Adding a power brake kit to a manual brake system [Re: JohnRR] #1302798
09/12/12 03:00 PM
09/12/12 03:00 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
Because fo the large engine
Re: Adding a power brake kit to a manual brake system [Re: 62BT409] #1302799
09/12/12 03:20 PM
09/12/12 03:20 PM
JohnRR Offline
JohnRR  Offline
Check with the street rod guys, but I think that has the pivot also down on the frame rail underneath ? Do you even have room under there ?
Is you issue pedal pressure ? If so you can fix that wit ha master cylinder with a different size piston .
You obviously have tried the small A body booster that is no the bracket that lifts it up attached to that offset adapter ?
Re: Adding a power brake kit to a manual brake system [Re: JohnRR] #1302800
09/12/12 05:28 PM
09/12/12 05:28 PM
Irwin, PA
62BT409 Offline OP
62BT409  Offline OP
Irwin, PA
Re: Adding a power brake kit to a manual brake system [Re: 62BT409] #1302801
09/12/12 05:52 PM
09/12/12 05:52 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Very nice! Can't help you on the brakes, though.
Re: Adding a power brake kit to a manual brake system [Re: bobby66] #1302802
09/12/12 07:04 PM
09/12/12 07:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
that car is so clean it doesn't look real! very nice dude!
Re: Adding a power brake kit to a manual brake system [Re: mikemee1331] #1302803
09/12/12 08:38 PM
09/12/12 08:38 PM
IN
ahy Offline
ahy  Offline
IN
A hydroboost system would likley fit. It gets its power from the PS pump (if you have one!).
http://www.hydratechbraking.com/
Re: Adding a power brake kit to a manual brake system [Re: ahy] #1302804
09/12/12 10:39 PM
09/12/12 10:39 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
What about manual disc's up front. Keeps the same size MC....i'm going to that setup this winter.
Still looking for LM29H1B415501, '71 Demon 340
Re: Adding a power brake kit to a manual brake system [Re: 62BT409] #1302805
09/13/12 07:10 AM
09/13/12 07:10 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
Better pictures here:
http://home.comcast.net/~jlbc11/sizzler.htm
Man that is one sweet ride.
