Check with the street rod guys, but I think that has the pivot also down on the frame rail underneath ? Do you even have room under there ?
Is you issue pedal pressure ? If so you can fix that wit ha master cylinder with a different size piston .
You obviously have tried the small A body booster that is no the bracket that lifts it up attached to that offset adapter ?
