4 speed differences #1301758
09/10/12 08:54 PM
09/10/12 08:54 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Are there any differences between the clutch and flywheel from a car with a 383 and another from a 440?
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: 4 speed differences [Re: CurYellowBird] #1301759
09/10/12 09:30 PM
09/10/12 09:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Not sure where to start with this one 440 could have 143 tooth 11" wheel where the 383 could be 130 tooth 10.5 wheel.In that case the bells would be different too.Some 440's had 18 spline transmissions where 383's had 23 spline boxes stock.Then you throw the whole 6 pack flywheel into the works and then you have a new quagmire
Gus
64 Plymouth Savoy
Dana 60
Re: 4 speed differences [Re: fourgearsavoy] #1301760
09/10/12 09:46 PM
09/10/12 09:46 PM
San Antonio, TX
San Antonio, TX
Basically what I'm trying to do is take my original flywheel, bell housing, and other components from my 383 engine and swap it onto the 440. Can this work or what parts do I need to get.
Re: 4 speed differences [Re: CurYellowBird] #1301761
09/10/12 10:22 PM
09/10/12 10:22 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
As long as the 440 is neutral balance then yes bell/flywheel will work.
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 4 speed differences [Re: CurYellowBird] #1301762
09/11/12 10:56 AM
09/11/12 10:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you going to use the same trans ? If so yes .
440's used the 18 spline trans , 383's used the 23 spline so the clutch disc will not swap ... obviously ...
