4 speed differences
#1301758
09/10/12 08:54 PM
09/10/12 08:54 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
Are there any differences between the clutch and flywheel from a car with a 383 and another from a 440?
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
Re: 4 speed differences
[Re: fourgearsavoy]
#1301760
09/10/12 09:46 PM
09/10/12 09:46 PM
CurYellowBird
San Antonio, TX
Basically what I'm trying to do is take my original flywheel, bell housing, and other components from my 383 engine and swap it onto the 440. Can this work or what parts do I need to get.
Project War Bird:
GY3 Curious yellow
All original
[Re: CurYellowBird]
#1301761
09/10/12 10:22 PM
09/10/12 10:22 PM
Posts: 4,285 Ohio
64dodge572
Ohio
As long as the 440 is neutral balance then yes bell/flywheel will work.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: CurYellowBird]
#1301762
09/11/12 10:56 AM
09/11/12 10:56 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Are you going to use the same trans ? If so yes .
440's used the 18 spline trans , 383's used the 23 spline so the clutch disc will not swap ... obviously ...
